| A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5-present |
#1 | ||
#2 |
It's similar to the 2009.. there is a long plastic hex head poking out from the back of the lens. I think it is a hex head but I used a open ended wrench on it and it worked.
Good luck.. just do not forget to never force anything!.. just in case you get it wrong! |
#3 |
Ok -- I think I remember seeing something like that yesterday - a long (at least 4 inches) piece of plastic sticking out, with a flat head and I think a square "hole" going the length of the plastic piece. I don't remember a hex head though. I'll have to double check tonight when I get home from work. Thanks for the feedback.
#4 |
I only have the instructions for my sedan, but the plastic screw with a slits sounds similar. Se attached instructions.
#5 | |
#6 |
All sorted and figured I'd circle back with the details in case someone else needs it.
- To unfasten the whole tail light housing I had to unscrew that plastic piece sticking out. Didn't need a wrench, there was a hole in the column that I just put a screwdriver in and turned. - After unscrewing that plastic piece the light unit came out pretty easy. I unscrewed the rubber ***** and the red plastic lens came off. - Autozone told me I needed a Sylvania 7506 Bulb but it was actually a 921 (W16W). About $5 for 2. - Replaced the bulb and put everything back and all set - easy peasy. Thanks again for the feedback earlier. -Don |
#7 |
when i bought y a4 b8 recently i wondered how to get bulb out an **** figure it out, i couldnt find nywhre on net that shown or toldyou how to get it out, but i looke at my light an figured it out yself, now i found this discussion which tells you how,
#8 |
This is way easier than others have described. ...if you are talking about replacing the tail light on the tail gate, that is.
On the 2009+ A4 Avant (B8) there is a tail light assembly on the tail gate and one on the rear corner of the body. The light bulb that went out for me was on the tail gate. On each side of the tail gate, there are two tail light bulbs and one back up light bulb. All three can be accessed without tools, and is very easy!
NOTE: BE SURE NOT TO TOUCH THE NEW BULB WITH YOUR BARE HANDS!! ANY CONTAMINATES ON THE BULB CAN MAKE IT BURN OUT FASTER!
Sam 2009 A4 Prestige Avant |
#9 |
2009 Audi A4Join Date: Mar 2009
That is true for halogen lamps. Typically these are headlights and fog lights.The rear of the car has no halogen lamps, so you may touch the lamps.
#10 |
Of course it doesn't help that the owners manual basically says to take your car to your local dealer to replace the bulbs (!). I was shocked to see that because I believe in the US, vehicle lighting must be designed to be user serviceable. I know VW caught a lot of flack for designing the high center mounted brake light on the Mk5 GTI impossible to replace without a trip to a dealer. VW landed up offering a free replacement service just for that light.
The Nice Car: 2013 Ibis White Audi A4 quattro 2.0T - Have HEX+CAN VCDS, PM Me The Hoopty Beater: SOLD 1987 Alpine White Audi 4000cs quattro "special build" |
| Tags |
| 2009, a4, a4avant, audi, avant, b7, b8, brake, bulb, change, changing, light, rear, replacement, tail |
