Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 05-06-2012, 07:42 PM   #1
Pchelka01
Default Disconnected the suspension module, now can't connect to xenon range
Is this just a Coincidence or is it because of the suspension module, also if it is not a coincidence than the self level for the headlight is discontinued?
Pchelka01 is offline   Reply With Quote
Old 05-09-2012, 05:18 PM   #2
P4Ring
Default That's the way the system works
The headlight automatic adjustment depends on data from the suspension control module. There r four level sensors, 1 for each wheel. They serve two purpose. One is to signal the system when air is needed and the other signal is used to set the headlight range.
P4Ring is offline   Reply With Quote
Old 05-10-2012, 12:06 PM   #3
Mike B
Mike B's Avatar
To be perfectly correct, I believe that only the left front sensor is involved in headlamp height regulation. IIRC, the left front sensor has 4 wires, the others have 3.
-Mike
Mike B is offline   Reply With Quote
Old 05-10-2012, 12:11 PM   #4
thejulex
It depends on both rear and front sensor to calculate angle the car lift/dips at.
thejulex is offline   Reply With Quote
