#1 | ||
P&P K24 Turbo ARP Headstuds 1.9 bar Wastegate Spring 3“ custom down pipe 3" Magnaflow ABT cam Custom Intercooler MSD Ignition Megasquirt Fuel Injection MAC 11C 2.5 bar map Greddy Profect B boost controller (18 psi) Water-Meth Injection Bilstein HD Shocks and H&R Springs Rebuilt Front calipers, Hawks alround,SS Lines V- 8 Master Cyl and rear disc upgrade 93 V-8 Ft sway bar |
#2 |
![]() Join Date: Apr 2003
The red "brake" light? It can be a bad accumulator ("bomb"), broken wiring to the hydraulics reservoir cap, same for brake fluid reservoir cap, loose belt on the hydraulic pump (I once found the adjuster screw completely unscrewed. Lucky I didn't lose it), etc.
#3 |
Most people only check the brake fluid for the brake warning light, but the brake system use hydraulic pressure to assist the brake. So check the hydraulic fluid for the power steering pump, since the pump provide the hydraulic pressure for the brake.
