Go Back   AudiWorld Forums » Audi Models » Audi Q3 /Q5 / Q7 » Q5 Discussion
Q5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
Old 05-06-2012, 10:25 AM   #1
Mrchntmarine
1973 Land Rover SeriesIII
Mrchntmarine's Avatar
Default max a/c button???
Driving down the highway the other day wondering why the car has no max button for the a/c - just hit it and it goes to max. I know you can turn the **** down to low. So, I start fiddling around with the a/c and thought I discovered a way, like pressing and holding a button, that the a/c went to max cooling. Is there such a "shortcut" ? Can't seem to remember if I was in my car now or my wife's, but it's driving me crazy and now I can't seem to find anything in he manual or duplicate it.
2012 Audi Q5 3.2 Convenience & Prestige Pkg, Glacier White/Cardamon
Mrchntmarine is offline   Reply With Quote
Old 05-06-2012, 10:51 AM   #2
audiofyl
2013 Audi S5
My Garage
audiofyl's Avatar
I've never looked for a way to immediately hit the high or low setting on the climate controls, but sometimes I use the recirculation button (the one with the curved arrow) so the A/C unit uses only the cabin air for a while. It seems to help get the temperature to a more comfortable point a little bit faster. Once you're at a comfortable point, switch the recirc mode back off so the air won't get stale. Of course, with you being in New Orleans with that wicked summer humidity, maybe nothing is going to help!
2009 Q5 S-line Ice Silver
2013 S5 Cabrio Phantom Black Pearl
audiofyl is offline   Reply With Quote
Old 05-07-2012, 09:08 AM   #3
OttoNY
OttoNY's Avatar
[quote=Mrchntmarine;24296568]Driving down the highway the other day wondering why the car has no max button for the a/c - just hit it and it goes to max. I know you can turn the **** down to low. So, I start fiddling around with the a/c and thought I discovered a way, like pressing and holding a button, that the a/c went to max cooling. Is there such a "shortcut" ? Can't seem to remember if I was in my car now or my wife's, but it's driving me crazy and now I can't seem to find anything in he manual or duplicate it.[/QUOTE
A MAX A/C function typically means a high blower speed in recirculate mode. Since, on Auto, when the car in hot inside the blower will already be set to high, all you need to do is press the "Recir" button to get the desired effect.
2012 Q5 2.0T, P+, Monsoon Grey/Black, NAV, 19" 5 Arm, Advanced Key
OttoNY is offline   Reply With Quote
Old 05-07-2012, 09:23 AM   #4
ThunderDent
2011 Audi Q5
ThunderDent's Avatar
Kind of like when you hit the defrost button it auto turns the blower setting all the way up to 11. And that's better because it's one better than 10.
Audi engineers must have been a fan of the Tap.
2011 Audi Q5 TFSI -- CUSTOM []S MODEL --
Ibis White/Cinnamon
[Premium+ :: []S-line :: MMI 3G/Nav+ :: B&O :: Black Headliner :: Flat-Bottom Wheel :: []S-Tronic Sport Shifter & Euro Boot :: Premium Titanium Q5 Mats :: Höen Exterior LEDs :: Black Optic []RS Grille :: 20" []S-Line+ Titanium Peelers w/Conti ExtremeContact DWS :: ECS Spacers (17.5mm) :: brembo Brakes/AR Track (Double-Slot/Dimple) Rotors/STOPTECH SS Braided lines :: Lowered/ST v1 CoilOvers (by KW) :: 034MotorSport Adjustable Control Arms & Sway Bar Links :: STāSIS Rear Sway Bar :: APR Stage III+, K04 []S3 Turbo & ECU Re-Map :: 034Motorsport HFC :: STāSIS Resonated Exhaust :: 365 hp/395 lb-ft. torque :: VAG-COM]
Custom Q5 OEM+ **Build Thread**
HERS- 2013 WRX Limited/Hatch
Dark Gray Metallic/Carbon Black Leather
5-spd/STi Shifter/Flat-4 Boxer/Turbo/265 hp, 244 lb-ft. torque/fully blacked-out ride
ThunderDent is offline   Reply With Quote
Old 05-07-2012, 02:08 PM   #5
mtberman
2011 Audi A4
In cars with manual HVAC, the "Max" button usually turns on the air recirculation and nothing else. It's (literally) the same setting as pressing both the AC button and the recirculation button. However, in some cars "Max" mode will actually allow the evaporator to reach a lower temp before the AC pump cycles off to prevent the evaporator from freezing up. I owned a Ford that cycled the AC compressor off at (IIRC) 45°F in regular mode but went down to 40°F if Max was pressed. Conversely, some cars have/had an "Eco" button on the AC that did something similar: The pump would cycle off to save fuel at a higher temp (like about 50°F) in Eco mode, but otherwise would stay on until 45°F.
In cars with automatic climate control, if there's a Max AC button it does three things: Sets the temp to its lowest setting, sets the fan to its maximum speed, and turns recirculation on. In some cases it also adjusts the compressor cycle as described above, but that's rare now that compressors have been made so much more efficient than they used to be.
Audi and many other makers now omit the Max button altogether. Recirculation is automatic unless you turned that off in the MMI settings. The system will run in "Max" mode if it needs to. If a user really wants max mode, they can set the temp to whichever extreme and leave it there for as long as they can stand it. If you've disabled automatic recirculation via your MMI settings, you'll need to press that button yourself.
2012 Q5 P+, Moonlight Blue with cinnamon interior
2012 TT, Scuba Blue with black leather
2011 A4 Avant (sold), Ice Silver with gray interior
mtberman is offline   Reply With Quote
ac, button, car, max
