| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
2004 A8 L 4.2 Platinum Beige w/ Amaretto Maple Copper GmbH Exclusive wood trim Alcantara Headliner/Extended Leather Rear Climate Control & Lumbar Ventilated & Massage Seats MFSW Shift Paddle upgrade W12 Rear bumper upgrade Dual Tray Tables Illuminated sills DVD Headrests Security Glass Refrigerator AMI XM BT |
#2 |
2000 Audi A8Join Date: Nov 2010
Has it ever been able to connect and communicate? If not make sure you have the correct drivers installed on your pc to be able to use the usb device, otherwise you could try going to control panel>device manager>select the device and change the property of the communication speed to a lower number(i think it is 10 by default)
#3 |
I don't think you even have the vag-com setting properly. The ports have to be setup,any free port will do.
#4 | |
#5 |
You could try bringing your car to another place, like Autozone or Advanced Auto Parts, they can pull codes for free
#6 | |
Plus if vagcom, wired correctly, won't read it, then neither will a code reader.
Mine: '01 A8 SWB Hers: '03 Allroad 2.7T Dog's: '90 Passat wagon |
#7 |
My 2000 had a similar issue, I was able to get communication by disconnecting the ABS module.
Its possible you have a module that is misbehaving badly and that is causing the problem. Try disconnecting the ABS first.
