Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B8 Platform) Discussion
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present
Old 05-06-2012, 08:46 AM   #1
Foogie
2010 BMW X5
My Garage
Default Supercharger Oil Change Interval
Anyone have any data on if/when we should have the oil changed in the supercharger unit?
2012 S4 Premium Plus, Ibis White, SRD, 19", B&O, Advanced Key, 3 pedals.
35/20 Ceramic Tint, Supercharged Badges
APR/Carbonio CAI
Eurocode Short Shifter (Coming Soon)
Foogie is offline   Reply With Quote
Old 05-06-2012, 10:15 AM   #2
m444
2011 Audi S4
m444's Avatar
I think the supercharger unit oil is considered a "lifetime fill".
If one is worried about it, 100k miles might be reasonable, see below from Eaton;
http://www.eaton.com/Eaton/ProductsS.../FAQ/index.htm
"Q: How often do I need to change the oil in my supercharger?
A: The sealed oil reservoir in a supercharger is designed to last the life of the vehicle. Changing the oil is not recommended unless you suspect contamination, leakage, or other issues like bearing failure. Also, if your vehicle has an abnormally heavy duty cycle, such as racing or towing, you could consider changing the oil at regular intervals such as 20k, 30k, 50k, or 100k miles depending on usage.
Q: I’ve decided I need to change the oil in my supercharger. How do I do this?
A: If you do want to change the oil there is one fill/drain plug on the front face of the front cover. It will probably be an Allen type plug. You will have to suction out the oil using a syringe or other method before replacing with new oil. Fill levels are dependent on application. New oil can be obtained from any GM or Ford service parts facility, or from one of the Eaton aftermarket supercharger partner companies or remanufacturers. Please make sure you do NOT use any other type of oil, including synthetic motor oils. These will cause failure.
OEM Application
Rotor Type
Size
Oil Fill (ml)
Oil Fill (fl oz)
Audi A6/S4
TVS
R1320
155
5.2
11 S4 P+, DSG, SD
m444 is offline   Reply With Quote
Old 05-06-2012, 10:18 AM   #3
shaikhasm
Eaton doesn't recommend changing the oil unless the car is used for racing or towing
2012 A6 3.0T|moonlight blue metallic|titanium grey
euro specs|S-tronic tranny|full LEDs|S-line exterior|19" 15-spoke rim|valcona leather comfort seats|good list of features
mods:Red calipers|AWE touring exhaust
shaikhasm is offline   Reply With Quote
2012, 30, 30t, a6, audi, b8, change, charger, interval, oil, oiling, s4, super, supercharger, system
