| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
#2 |
1.Gas smell not likely to have anything to do with cats.
What codes have you read? How many miles on the car? 2. Depends on yearly mileage and your type driving. I've gotten about 35-40 miles out of front and rear pads...and double that out of rotors...2 sets of pads before rotors reach thickness wear limit...that's always been the case with every German car I've had (have).
Mine: '01 A8 SWB Hers: '03 Allroad 2.7T Dog's: '90 Passat wagon |
#3 |
![]() Join Date: Apr 2003
If your rear pads wear faster than your fronts, you have sticky parking brake issues.
#4 |
Havent done a scan just yet, has approx 150k (miles) runs great, just damn smell, last scan I did I remember, things related to Cat, O2 Sensor and some misfires, etc...
#5 | |
If they are the originals, they need to be changed...will smooth the engine and usually improve mpg's a little. 100K is about the limit on those.
#6 |
1999 Audi A8Join Date: Aug 2011
If you are smelling raw gas, I'd suggest you forego driving until you rectify the problem.
The fuel system on the A8 is not that complicated. Start from (you pic-it) one end checking as you go for leaks. A good place to look first is for loose fitting on or near the fuel rail under the dress covers/trim over the engine. If you don't find it there, go to the "boot" and check the pump fitting, filter, filler pipe, etc.. pc |
#7 |
2001 Audi A8Join Date: May 2012
My first post...
I'll second what "pocketchange" said above. Raw gas smell manifested itself when I opened the sunroof as well (with a full gas tank). The problem was in the trunk. The locking ring for the fuel level sender (driver's side under carpet near back seat) was loose and resulted in gas leaking into the trunk. I also had a P0455 CEL (large EVAP leak) because the tank wouldn't hold vacuum. A loose gas cap can give you the same error. |
#8 | |
The leak detection pump (up in left rear fender well) pressurizes the air space in the tank (and entire evap system) every time you start the car, then times any bleed down of vapor pressure, to detect any evap (tank vapor) leaks...quick bleed down=large leak...medium speed bleed down of pressure=small leak. VERY slow or no bleed down=system OK.
