Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 05-05-2012, 06:56 PM   #1
abarmard
abarmard's Avatar
Default Error code free LED lights
Just FYI,
IJDMtoy has al the Error free LED lights, you can imagine. I upgraded the city lights and license plate lights
Already. Maybe a little expensive but works well.
A.
abarmard is offline   Reply With Quote
Old 05-05-2012, 08:37 PM   #2
Brozee
2007 Audi A8
My Garage
Brozee's Avatar
What year is your car, there has been numerous attempts at LED's in the city lights and it has only worked a few times, and when it has it has been on a 04 A8. I recently swapped mine out for some cool blue xenonmatch's and have no code whatsoever as they are the same bulb as the stock one just a bit brighter with a blue'ish output.
Have you actually put in the LED's and had them work good w/ no code. I'd be surprised if you don't have an 04 though... As for the license plate lights I've had those as LED's for almost a year now, as long as you get the polarity correct they work perfect. Mess up in the beginning and the license plate lights won't work for about an hour.
2007 A8L 6.0L W12 Fully loaded every option
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1
VCDS Mods: belt chime delete, remote window control.
2005 A8 4.2L w/ all packages.
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control.
Popular Topics & Help for Noobies:
Oil Change Procedure
Disable TPMS System
AMI Installation
AMI Update (Phone not pairing)
Remote Window Control
Enable Hidden Menu & Enable Battery Meter
Fog Light Replacement
City Light Bulb Replacement
Door, Trunk, & Glove Box LED Change
Cabin Air Filter Change
Maintenance & Common Problems
Brozee is offline   Reply With Quote
Old 05-06-2012, 04:40 AM   #3
snapdragon
snapdragon's Avatar
The ebay honk kong license plate warm-white LEDs on mine needed 2W resistors piggy-backing on with solder. Without these they would turn off and error message.
I found that for the purpose of errors, they are treated by the car as a pair.
Even if only one has a 2W resistor (of the ohms for 2W at 13v) then there is no error.
The same happens if one old incandescent is left in one of them and LED in the other.
If I was doing it again, I would use 2w resistors but only burn 1w on each one to keep them cooler.
snapdragon is offline   Reply With Quote
Old 05-06-2012, 07:20 AM   #4
Brozee
2007 Audi A8
My Garage
Brozee's Avatar
The license plate LED's I got didn't need any additional resistors or anything. I got mine from tunerdomes.com for about $30?
Disable TPMS System
AMI Installation
Old 05-14-2012, 04:07 AM   #5
abarmard
abarmard's Avatar
I also bought the eBay Hong Kong License plate lights. Still waiting to receive them after 3 months!!!
Old 05-14-2012, 11:00 AM   #6
A8CT
I wasn't looking for a lic plate LED upgrade but one of my lights was broken. I got a pair from ECS and they work fine, no codes.
They are insanely bright and will probably add a little back up light too but haven't tested that yet.
2005 Audi A8L
2000 A8, silver/blk, all options
A8CT is offline   Reply With Quote
Old 05-14-2012, 11:26 AM   #7
Brozee
2007 Audi A8
My Garage
Brozee's Avatar
A8CT please take pictures from somewhat close and a bit further away. I have LED's from tunerdomes.com and they work very nicely. It is a small board with 4 led's on them which fits in the existing housing.
Disable TPMS System
AMI Installation
Old 05-14-2012, 06:26 PM   #8
Lexdiamondz10304
Ask for a refund then buy from a us seller. That's what I had to do after 2 weeks of not receiving my product. The seller actually told me he did not have them in stock.
The lights once installed are pretty bright, a little too bright in my opinion. They refract light of the bumper chrome trim (worse if you have a chrome plate frame), which sucks.
Lexdiamondz10304 is offline   Reply With Quote
audi, clear, code, error, headlight, headlights, led, lights, s8, stop
