Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B8 Platform) Discussion
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present
Old 05-05-2012, 02:54 PM   #1
RCM09
RCM09's Avatar
Default Bad start for my S4...
I started my car today and all kinds of errors started lighting up my dash.Looks like a trip to the dealer.
Here's the log file.
Saturday,05,May,2012,16:05:11:07319
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 22 36 42 46 47 52 53 55 56 5F
62 6C 72
VIN: WAUDGAF Mileage: 3460km/2149miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H08 0001
Revision: --H08---
Coding: 0104000A180F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001001
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 3261370B6534403
2 Faults Found:
6201 - Function Restriction due to Received Malfunction Value
U1113 00 [109] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 3464 km
Date: 2012.05.05
Time: 15:00:17
6134 - Function Restriction due to Received Malfunction Value
U1113 00 [109] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 3464 km
Date: 2012.05.05
Time: 15:01:46
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 280D1A
VCID: 820127CB1D14B03
3 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:03
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0320
Hex Value: 0x0009
Hex Value: 0xB09C
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:17
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x03A2
Hex Value: 0x0032
Hex Value: 0x0291
Hex Value: 0x00FF
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:17
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x03A2
Hex Value: 0x0028
Hex Value: 0x5091
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 0F0100
VCID: 77F7C61FC6D665B
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:42:04
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01040920110105
Coding: 66102000
VCID: 80052DC31318A23
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001193940
Coding: 26001011043CAF212600000300003D0D4F9C92480201016100 0000
VCID: 3C7D1933BF70863
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290811 H07 0070
Coding: 00F511
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0081
Revision: 11001001 Serial number: 36861124300653
Coding: 20000D
VCID: 4A914FEBE5A4283
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0NYR8G
Coding: 303837354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 458B7CD7C4BAC7B
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100004BV1
Crash sensor for side airbag; driver side:
Serial number: 6334MSME6361577AI
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME6365784AN
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME175E236CR
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME2C5C2452M
Crash sensor for front airbag; driver side:
Serial number: 63732SME3F5C18549
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7F5C0B6ER
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KHL0004V
Coding: 000016
VCID: 3E79133BA96C943
Component: E221 - MFL H02 0010
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:16
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
Component: KOMBIINSTR. H12 0258
Revision: 00000000 Serial number: EJG44RX8C
Coding: 831D09008300D705020000
VCID: 418368C7D892EBB
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E118160368
Coding: 00C303
VCID: 830F22CF020EB9B
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H12 0025
Serial number: 002107110001014
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E59237B710C643
2 Faults Found:
0090 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 3464 km
Date: 2012.05.05
Time: 15:00:17
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 58
Mileage: 3464 km
Date: 2012.05.05
Time: 15:00:17
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00000012063052
Coding: 00581B00000000000000
VCID: 3B7F1A2FBA7E81B
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C13204E00410001
VCID: 53AF528F32EE69B
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0157368898
Coding: 0106023A00FA444580B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804009334902
VCID: 7AF1DF2BF5C4783
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52A1578B0DF4603
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000842653
Shop #: WSC 00000 000 00000
VCID: 346D311397204E3
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:16
Freeze Frame:
Voltage: 11.20 V
Count: 62
Speed: 0.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0202
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 397300277042B3B
1 Fault Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 3464 km
Time Indication: 0
Date: 2012.05.05
Time: 15:00:26
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H51 0076
Revision: AB001007 Serial number: 471E10B7579283
Coding: 020007010000000001
VCID: 1F47CEBF0EA6FDB
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
Component: H-BN-NA H52 0165
Revision: -------- Serial number: 490I+0B7637109
Coding: 010200000206E1EF45000F0E000000030000
VCID: 39730027B042B3B
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C13204000210001
VCID: 56A9AB9B211C7C3
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J12935C
Coding: 1000006
VCID: 387505234B48AA3
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1501
End ---------------------------------------------------------------------
2009 Q5 Sline/Prestige....Sold
2012 S4 P+ 6MT,Monsoon,Sport Diff,Nav,Sensors,Ad Key,B&O,19's
RCM09 is offline   Reply With Quote
Old 05-05-2012, 03:27 PM   #2
gk1
2012 Audi S4
My Garage
gk1's Avatar
All roads seem to point to an ABS malfunction.
3 Faults Found:
All the other alerts appear to be activated based on the fact that there is an ABS fault.
If it is just the sensor it should be an easy warranty fix.
2012 S4 S-Tronic Monsoon Gray
Black Alcantara®, Carbon, Adv.Key, B&O, Sports Diff, NAV & park, 19's
Eurocode Alu Kreuz
Past:
2008 A6 3.2Q S-Line Daytona Gray
2007 A4 2.0T S-Line Ice Silver
2001 S4 Nogaro Blue
gk1 is offline   Reply With Quote
Old 05-05-2012, 03:50 PM   #3
waffles
do you need a vag-com cable or is there an easy way to get the log file when errors happen?
waffles is offline   Reply With Quote
Old 05-05-2012, 04:09 PM   #4
mark_nimda
2013 Audi A8
wow, sorry to hear. Atleast you didnt get a Divide by Zero error
Hang in ther man. I have had a few issues also that have inconvenienced me and I am certainly not use to going into service as often as I have had to so I am a bit spoiled
2011 S4 - A RED Lemon. Repurchased by AoA due to multiple problems
2013 A8 NWB- White/Velvet Beige, B&O Sound, Convenience Pkge, Comfort Pkg, Warm weather pkg, Full LED's, 20" parallel Spokes, Custom Piano Black Inlay Order
mark_nimda is offline   Reply With Quote
Old 05-07-2012, 05:46 AM   #5
zulujams
RCM09, good luck with the car.
Waffles, VCDS is vag-com. You can get the cable from http://www.ross-tech.com/. Some feel that the cable is a little pricey, but besides being able to make a lot of settings changes you can scan your car when your dash lights up in bad ways. This kind of info can help you determine if you need a tow or can drive the car to get serviced. Hope this helps!
Current: 2013 Focus ST
Former: 2010 S4; 2007 Passat 3.6 4Motion; 2002 Passat 1.8; domestics before that
zulujams is offline   Reply With Quote
Old 05-27-2012, 04:29 AM   #6
RCM09
RCM09's Avatar
Just got my car back from the dealership yesterday. I had lost the battle with mice getting into my car(I don't drive it enough).
They did 2400 dollars of damage to my car. They chewed up some wires and the dealership had to take the rear seats and carpet out to check for damage. So much for living out in the sticks and not having a garage.
I had tried dryer sheets, peppermint oil and set traps around the car,I killed 3 that week in my traps! Well I guess I'm going to have to let my wife take it to work so it doesn't sit all week.
Old 05-27-2012, 07:27 AM   #7
bbmaster
2010 Audi A5
My Garage
bbmaster's Avatar
?? Mice getting into car? Are you serious?
1st Ring: 2003 A4 1.8T Brilliant Black/18" RS4 replica/Hankook W300 Ice Bear
2nd Ring: 2010 A5 2.0TFSI Quartz Grey/Premium/S-line/Nav/B&O/3M/18" Moda MD11/Pirelli Winter 240 Sotterzero
3rd Ring: 2011 S4 3.0S/C Phantom/Mustang Nappa/Nav/Rear Differential/Custom 3M Clearbra Full Front End/32% Tint All Windows/Continental ExtremeContact DWS/VAG-COM
4th Ring: TBD
bbmaster is offline   Reply With Quote
Old 05-27-2012, 08:08 AM   #8
DrGP
DrGP's Avatar
In the past, I have had issues with mice building nests inside the engine compartment and squirrels chewing the wires off as well. Note to the OP. Perhaps your home owners insurance could cover the damage. Worse they could say is no. Probably have a chance if you have the same insurer for car and home.
DrGP is offline   Reply With Quote
Old 05-27-2012, 10:44 AM   #9
zulujams
A mouse started building a nest on top of my engine...twice. They tore into a family member's Toyota's air and cabin filter around the same time. The Toyota dealer recommended moth ***** but would not say where or how to place them. My best idea so far is a bird suet feeder type of cage, but finer mesh. Fill it with moth ***** and attach it somewhere in the engine bay. I haven't tried this yet. You wouldn't want moth ***** too close to the cabin filter unless you really like the smell of moth *****. Might be worth trying. I've had success winterizing the lawn tractor and motorcycle with hole-poked ziplock bags of moth ***** as well as ziplock bags of steel wool in the intakes, exhaust pipes, etc.
Old 05-27-2012, 11:14 AM   #10
RCM09
RCM09's Avatar
With mothballs...they told me to put them around the tires. That's how they get up into the car.
My insurance did pay for it under comprehensive, I just had to pay the deductible and no affect on my future premium.
airbag, audi, b8, crush, damage, defaut, driver, frame, passat, q5, sensor, side, u1017, vin, waud
