Go Back   AudiWorld Forums » Audi Models » Audi Q3 /Q5 / Q7 » Q7 Discussion
Q7 Discussion Discussion forum for the Audi Q7 SUV
Sponsored by: Audi
Old 05-03-2012, 06:52 PM   #1
eggyacid
2011 Audi Q7
My Garage
eggyacid's Avatar
Default Yakima Rail Grab
I've been searching for a set of roof racks for our Q7 2011 TDI
We will be using it primarily for Kayak and maybe a cargo box
Whispbar - we can leave it on all the time but expensive
OEM - sits higher but I've always like OEM
Yakima rail grab - look like the simplest solution, just attaches to the existing rail and cheap ($250)
Any recommendations? Anyone using it for Kayak?
- Jeff
2011 Q7 TDI PPlus
2010 Chrysler 300C
2006 Infiniti M35
2004 VW Tourage V8 (GONE)
www.chunkysalsa.net
eggyacid is offline   Reply With Quote
Old 05-04-2012, 02:48 AM   #2
knepster1
I have the rail grab system, but you need to take the front rail off when not in use as it intefers with the sunroof,
The back roof opens fine.
Also, you want to make sure you order a special pin/claw system that locks the towers into place.
http://www.etrailer.com/Accessories-.../Y8880201.html
Pros-Cheaper alternative and pretty low profile
Cons- No sunroof
knepster1 is offline   Reply With Quote
Old 05-04-2012, 04:43 AM   #3
eggyacid
2011 Audi Q7
My Garage
eggyacid's Avatar
thanks... i definitely want to operate my sunroof with it... so i guess grab rails are out.
OEM or Whispbar are my other choices.
- Jeff
2011 Q7 TDI PPlus
2010 Chrysler 300C
2006 Infiniti M35
www.chunkysalsa.net
Old 05-05-2012, 04:10 AM   #4
Bklyn_Quattro
Bklyn_Quattro's Avatar
Thule Aeroblades
Now:
2011 Q7 3.0TFSI S Line Prestige
Then:
2008 Q7 3.6 Premium
2004 Audi A4 Avant
Bklyn_Quattro is offline   Reply With Quote
Old 05-24-2012, 06:16 AM   #5
phillips2024
phillips2024's Avatar
the yakima system for the Q7 is AWFUL!
dont get me wrong, i like yakima systems, use to sell them for a summer job and had them on previous cars. May buy a system for my s4 but they dropped the ball hard on the q7 application. extremely poor fitment. I had to actually call yakima for extra pieces to make it work semi-properly
2011 Audi S4
BB|6MT|Prestige|Red Nappa|Carbon Inlays|Carbon Grill|Carbon Logo|VAG-COM|Valentine1|3M Clear Bra|H&R OE Springs|35% tint|Carbon Ribbed Rear Diffuser|LM's 225/40/19|Trispoke 225/40/19|10/15mm spacers|Hoen endurance fogs|j-codes|AWE Boost Tap|Podi Boost Gauge|Eurocode Short Shift|Roc-Euro Intake|Whispbars|Skybox|AWE Exhaust
phillips2024 is offline   Reply With Quote
Old 05-24-2012, 08:47 AM   #6
knepster1
As long as you order that pin/claw accessory I mention above, they clip on fine. However the drawback is the front sunroof will not open with the bar in place.
Old 05-24-2012, 09:03 AM   #7
phillips2024
i respectively disagree
2011 Audi S4
Old 06-01-2012, 03:32 PM   #8
CharleyQ7
2011 Audi Q7
Default modifying for sunroof clearance?
I had the GrabRails already for my old car, and managed to snag the Audi pin adapters from etrailer.com for $0.01 plus shipping (that's their online price!)
The install took about 10 minutes, and it's a very positive connection.
There is a little bit of a clearance issue with the front sunroof panel, but the overlap seems to be less than 1/4". Has anyone tried grinding away the inside corners of the front GrabRails to allow clearance for the glass panel? I'm tempted to do so this weekend.
CharleyQ7 is offline   Reply With Quote
Old 06-02-2012, 07:26 AM   #9
knepster
there is a phillip head screw in the way of allowing you to shave the corner down.
knepster is offline   Reply With Quote
a4, adapter, audi, bar, grab, pin, q7, rail, whispbar, y8880201, yakima
