Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 05-03-2012, 01:32 PM   #1
cjeffers1
Default need cam aligning help
can't align driver side cam, when aligning tool is removed cam "springs" forward will not stay at proper aligned position. Any thoughts? (A8 D3)
cjeffers1 is offline   Reply With Quote
Old 05-03-2012, 01:41 PM   #2
mishar
2005 Audi A8
mishar's Avatar
Welcome!
What are you doing? Why are you removing aligning tool before the timing belt is in its place?
mishar is offline   Reply With Quote
Old 05-03-2012, 01:44 PM   #3
A8CT
no worries, just "grab" it with the cam bar and pull it back. It sometimes takes me a couple of tries if the other side is off a hair. The left cam will hold in position a lot easier than the driver side.
Are the cam sprockets free to rotate? If you have the timing belt on the sprockets, same comments applies.
Bob
2005 Audi A8L
2000 A8, silver/blk, all options
A8CT is offline   Reply With Quote
Old 05-03-2012, 01:50 PM   #4
cjeffers1
Originally Posted by mishar View Post
Welcome!
changing timing belt...newbie..... when old belt was removed sprockets stayed in place was just a little worried. Thanks
Old 05-03-2012, 01:51 PM   #5
cjeffers1
Thanks Bob!
Old 05-03-2012, 02:22 PM   #6
mishar
2005 Audi A8
mishar's Avatar
Thanks is nice but I don't see what for. You haven't got any help.
Old 05-05-2012, 06:42 AM   #7
Mister Bally
He sure did (Benji) get help. A8 CT mentioned to just turn it back slightly as this is normal with this engine. I concur as I experienced the same thing when I replaced my belt and all of the associated stuff in mine almost two years ago.
Mister Bally is offline   Reply With Quote
Old 05-05-2012, 07:48 AM   #8
mishar
2005 Audi A8
mishar's Avatar
And when you turn it back it will stay there? Why would you use alignment tool if you are going to play with it afterwords?
Old 05-05-2012, 07:56 AM   #9
A8CT
You have to rotate one or both cams to get the holes to line up. The driver side usually does not stay in place.
Old 05-05-2012, 08:00 AM   #10
mishar
2005 Audi A8
mishar's Avatar
Which holes you are talking about?
a8, aligned, audi, bar, cam, locking
