| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#11 | ||
99.5 A4 Q 2.8 - 179,000 miles Hibiscus Red Mica |
#12 | |
Incorrect release Bearing adjustment /Inadequate clearance causing overheating of the bearing and loss of lubricant , plus overstroking of the clutch and excessive Clutch Diaphram / Lever and Clutch Disc wear. Riding the clutch Pedal Waiting in traffic with the vehicle in Gear and Clutch disengaged is a major contributing factor, this loads the clutch release bearing excessively and shortens both the bearing and clutch assembly life drastically. Bad driving habits such as resting the foot on the clutch pedal while driving the vehicle is also one of the major causes of premature clutch failure common sense if your driving a stick shift car....If you guys think none of this causes any wear on the manual tranny. then its time for you guys to do some break down on two different cars driven differently. Im guessing 75 % of manual drivers keep there clutch pedal clutched in at a red light. |
#13 |
You've completely changed your tune. I agree with most of what you said above, but what I don't get is:
I still have no idea what this means. The TOB sits on the input shaft of the trans. How does it get out of alignment? TOB's see wear at every shift. If you never ride your clutch and never hold it at a stop light, it will still wear out some day.
#14 | |
#15 | |
2001 Audi TTJoin Date: May 2002
The bearing wears out, you replace it. It's that simple. To replace the bearing you have to remove the gearbox.
2001 180 TTQ coupe 1976 Triumph Spitfire 2008 A4Q 2.0T (sold) 2003 A4Q 1.8T (sold) 1996 A4Q (sold) |
#16 | |
#17 |
It's your brakes I guarantee u, I replaced my brakes and now I have the same annoying noise I'm still trying to figure out this problem...People have said it could be cheap pads, worn caliper bracket , dry caliper bushings, retaining clip ...when I find the answer I'll let u know unless u find it 1st haha
#18 |
My bad I misread the thread...:-)
| Tags |
| 18t, 2005, audi, click, clicking, clutch, knocking, noise, pedal, pressed, push, pushed, pushing, stops, tapping, ticking, tt |
