Old 05-02-2012, 10:21 PM   #1
Danomatic93
Default Engine won't shut off
2000 A6 2.8L Quattro Auto
This has happened a few times now and I figure I should address it before it's too late.
I'll drive a short trip, stop, put the car in park, turn the key to the off position and remove the key but the engine will continue to run!
The only way I've been able to shut it off is hitting the brake pedal a few times or taking the car out of park.
Any suggestions on what to look into?
Danomatic93 is offline   Reply With Quote
Old 05-03-2012, 03:34 AM   #2
GTA_Driver
2005 Audi Allroad
GTA_Driver's Avatar
Ignition switch
GTA_Driver is offline   Reply With Quote
Old 05-03-2012, 07:12 PM   #3
Danomatic93
Is that one whole module or is the key tumbler able to be separated? I guess what I'm asking is, do I need to get new keys too?
Old 05-03-2012, 07:28 PM   #4
Danomatic93
Okay, google is a help tool.
It's separate. Now, Any vendors you would suggest that have a quality replacement?
Old 05-30-2012, 05:14 AM   #5
Danomatic93
Update:
I replaced the ignition switch with an new OEM switch. The problem has reoccured twice since then.
Is there an ignition relay that could be sticking closed??
Both times that it happened I had removed the key and the engine stayed on along with the cluster being on too. I was able to turn off the engine by pressing the brake pedal for 5 seconds.
Old 05-30-2012, 07:46 AM   #6
ezveedub
2012 Audi Q5
My Garage
ezveedub's Avatar
Did you do any work to your driver's side sun visor? Remove the sunvisor and see if the wires are pinched and shorted together. This used to happen and it would keep the terminal 15 power on.
ezveedub is offline   Reply With Quote
Old 05-31-2012, 07:59 PM   #7
Danomatic93
I did replace the visor with a different one not too long ago because the original one wouldn't go up. Either way, I checked and found the black wire must have been pinched at some point. It didn't seem as though it was shorted to the black wire but, just to be sure I wrapped them in electrical tape individually. Those are for the HomeLink right?
Fingers crossed again.
Old 06-01-2012, 05:20 AM   #8
Boston Driver
AudiWorld Expert
Boston Driver's Avatar
Homelink, switch for the mirror light, etc. but there are so many things tied to that circuit.
2002 A6 4.2 Sport...with a few things added
Boston Driver is offline   Reply With Quote
Old 06-01-2012, 09:16 AM   #9
ezveedub
2012 Audi Q5
My Garage
ezveedub's Avatar
Yes, and for the lights in the visor like Boston Driver said. Tape up the wires to insulate them and make sure them are routed properly when installing the visor, then see if your issue still happens. It sounds odd and I don't have the wiring diagram in front of me to explain it, but that used to cause the car not to shut off when the wiring issue with the visor happens.
Old 06-01-2012, 09:38 AM   #10
GTA_Driver
2005 Audi Allroad
GTA_Driver's Avatar
Amazing. The more I learn about Gean engineering, the more I'm baffled.
Turn the ignition Off, the radio goes off. In most other cars it keeps playing as long as the key is in the ACC position.
But damn if turning te ignition off cuts off my vanity mirror light! How else am I supposed to pick my teeth or put eye liner on?
a4, audi, engine, motor, shut
