| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#1 | ||
2005 Audi A8Join Date: Mar 2012
#2 |
I'll follow this thread with interest, purely because I have this issue. I've had ZF give it a complete once over and they gave the trans a raving review.
A8 4.2 S
#3 |
Who did the fluid refill? Very easy to underfill these transmissions and results in the symptoms you have.
Can you add more details about what fluid was used? Was the filter replaced at the same time? Bob
2005 Audi A8L 2000 A8, silver/blk, all options |
#4 |
Senior Member
the classic 6HP26 "hoot" issue; classic scenario should be in 4-5 shift. Fix there is the expensive "blue" fluid. Search archives for "hoot" for many posts and TSB about it. Jag has also issued a similar but less insightful TSB for the RWD version of the same ZF tranny.
Per other replies, have fluid level checked by someone who knows ZF trannies and Audi's--while running, level car, specified fluid temp.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
| Tags |
| 2005, 2005a8, a8, audi, problems, shifting |
