| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#1 | ||
2005 Audi A8L 2000 A8, silver/blk, all options |
#2 |
2005 Audi A8Join Date: Nov 2010
Yes.
#3 |
2005 Audi A8Join Date: Dec 2011
Thanks Bob! That eases my mind a little. I had my new rims built up without them, but I'll get them put in now! Do you have a product link please? I think there's one in a thread on here, but could you help me with the exact part pls?
K9 |
#4 |
the only weird thing I've noticed are the identical pressures indicated between tires, although the OEM sensors did the same in the week I've owned the car.
Right now, my two front tires are 33.3 and I believe the rears are 35.9. How could they be exactly the same? Not that I care about fractions of a pound but it almost seems like the synch up in pairs.
#5 |
Your fronts are low. First pump one up and check if they are still same.
#6 |
The car is not picking up the individual sensors - I suspect the ones you have are all shipped with the same ID.
A8 4.2Tdi, 06, Grey/Grey - my new toy - how can a diesel be this fast? 2010 A4 2.0tdi 6 spd SE Executive avant - dark blue & Vanilla - Wife's new one. VW Touareg 06 30k 6spd 2.5Tdi - Wifey's new one, A4 was not big enough! A6 2.7t 01my 6spd Avant 51k miles - Sold Dec 2011 - Gone to Banbury A4 2.0FSi SE 03.8 22k miles - Wifey's new one - the golf was not luxurious enough. Sold 30/08/08 - gone to Heathrow. Golf Tdi 03.08 130pd, 6spd, 19k miles - Sold 8th November 2006 - gone to Coventry! A6 2.8q 98.11 115K miles - sold 20th Feb 2006 - gone to Kidderminster. 100 2.8q 92.1 147k miles - Sold 6th July 2004 - its new home is Edinburgh A4 1.6 97.8 99k miles - Sold 12th Feb 03 VW Golf Gti 86 22k miles 2.0 Oettinger 190bhp, lowered, lightened and quick and sold 23/03/08. Gone to Coventry. |
#7 | |
2012 Audi A8LJoin Date: Feb 2011
Mine are exactly the same after about a minute of driving. Makes an OCD person like me smile big ![]() EDIT: Did you tell MMI they were new ? Can't remember exactly what it's called {replace wheels?}, but it learns the sensors after tire rotation, etc.
2012 A8L 4.2 Oolong/Titanium. Premium, LED, Driver assist, Rear seat comfort, Dual pane, Alcantara, Panorama ![]()
#8 |
2007 Audi A8My Garage Join Date: Jan 2010
I keep mine at 36 in the fronts, and 40 in the rears
2007 A8L 6.0L W12 Fully loaded every option Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. 2005 A8 4.2L w/ all packages. Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. Popular Topics & Help for Noobies: Oil Change Procedure Disable TPMS System AMI Installation AMI Update (Phone not pairing) Remote Window Control Enable Hidden Menu & Enable Battery Meter Fog Light Replacement City Light Bulb Replacement Door, Trunk, & Glove Box LED Change Cabin Air Filter Change Maintenance & Common Problems |
#9 |
Senior Member
On point, yes identical readings seem hard to believe. Check them on road and then see if they vary. If not, suspicious. If spare is reporting in, it shouldn't vary much of course from parked to running. The temp reading would be the other giveaway. Just park car in sun on one side and if they don't vary temp wise after car sits a while, something is wrong. Simple low tech diagnostic.
On the W12 for trivia (and maybe S8's?), the right front runs hotter than any other position, and in turn pressure reading pushes up a bit too. That would be the auxiliary cooler up in front of the wheel with the punched venting through the right side fender lining. Tire warmer. Tells me all is well w TPMS and that extra cooler. For anyone who wants perfect symmetry on his/her TPMS screen, don't buy a W12, or at least don't ever take it out of the garage. Meanwhile, interesting as I continue to follow the possible aftermarket solution. I won't be going here though. W/ a week to go on my CPO, I left the TPMS trouble light on by not resetting sensors and went in for what I thought was my last warranty pass. On prior visit, they said light had to be on to validate. For the $50 old CPO deductible, first I got 4 new sensors installed; I only expected 3 max since one was replaced several years back but they did all 4. Actual VAG COM reading was two at 0 estimated months (which dropped suddenly from 8 or 9 just a month or two earlier when I scanned), one at 14 and one at around 50 IIRC. Then when spare didn't read after I picked car up, I got the 5th one replaced on my last day hoorah of CPO. Hoping the aftermarket viability will be sorted by 6 more years, though there are the winter wheels...
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#10 |
Do you drive three persons and packed trunk all the times? If not than rears should be lower than fronts.
| Tags |
| a8, audi, audiworld, distributors, electronic, electronics, oe, orange, proformance, reviews, sensors, tips, tire, tpms, wheel |
