| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#11 | |||
2005 Audi A8Join Date: Nov 2010
#12 |
In my opinion brakes are the last ones where I would go just for looks.
#13 |
Do the EBC reds come with sensors, or is that an extra part I need to buy?
Keep the shiny side up MikeC 07 A8 SWB Sport and Pref package. 02 S6 Avant |
#14 |
They come with sensors.
And I can attest to the low dust factor. It's truly remarkable after having factory pads on for a long time.
2005 A8L 4.2 Silver on Black Leather / 5K range HID Headlamps / Fog Lamp Conversion to 3K range HIDs / Interior LED Conversion / Multiple VAG changes to suit (more coming, as nuggets are uncovered) / 19X8.5 Turbines with Conti DWS rubber / AMI Upgrade / Parktronic upgrade "The computer should work for you, not the other way around."
#15 |
Senior Member
plug directly into the stock Audi connectors.
On the front that is. The rears (including Audi OEM) don't have sensors; they rely on the parking brake motor positioning system to calculate wear.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#16 |
Before getting the $19.00 rotors from Tire Rack; Yes, they look good and are made by Continental-Teves (ATE branded rotors). I bought 'em along with the clearance pads (also ATE). When it came time to install them, they were 2 or 3 cm too small in diameter. I had to run out and buy the real McCoy's for a *slightly* higher price.
If anyone wants them, they are free to any regualr poster here. Pick them up in 48188 or I can drop them off on one of my regular Detroit -Chicagoland runs. Tire rack said no refunds on clearance items and I'd have to pay for return shipping. I still did not lose as the low priced rear pads made it worth it. Veryy little dust (versus stock) and they stop just as well. |
#17 |
2007 Audi A8My Garage Join Date: Jan 2010
I'd like to have em bally, and I am very close to detroit as well. Thanks man!
2007 A8L 6.0L W12 Fully loaded every option Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. 2005 A8 4.2L w/ all packages. Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. Popular Topics & Help for Noobies: Oil Change Procedure Disable TPMS System AMI Installation AMI Update (Phone not pairing) Remote Window Control Enable Hidden Menu & Enable Battery Meter Fog Light Replacement City Light Bulb Replacement Door, Trunk, & Glove Box LED Change Cabin Air Filter Change Maintenance & Common Problems |
#18 |
I can attest to the EBC RedStuff Pads. They are very low dust, stop very well and were a decent price. The connectors for the front plug right into the Audi connector. They do take about 300-500 miles to wear in properly and you do need to follow MFG instructions for break in. For typical A8 driving these work very well.
#19 |
I'm a huge fan of Akebonos and will be driving around with my brakes on so I can replace the OEM pads ASAP
They don't make a sound but the brake dust is a killer. If bedded correctly, the Akebono's are just as quiet.Does anyone know the correct Akebono Euro part # for an early '05 (if that makes a difference)?
2005 Audi A8L 2000 A8, silver/blk, all options |
#20 |
| Tags |
| audi, brake, ebc, premium, reviews, rotors, slotted, ultramax |
