| Audi allroad Discussion forum for the original Audi allroad |
#1 | ||
2003 Audi AllroadJoin Date: Oct 2007
1987 5000cs Turbo Quattro ~ Sold 1998 Audi A4 2.8L ~ Sold 2003 Audi allroad 2.7T, Stage III, K04's and 6 MT Swap ~ Current Ride |
#2 |
+1
I'd like to hear it - see it, and know if it's possible.... |
#3 |
Several did and I about to do the same since I needed a tranny rebuild anyway. The upside is that it eliminates problematic oil pump, lines and cooler and you gain much better gearing ratio much better suitable for actual road car, not some offroad vehicle which allroad is not.
What's needed: - S4 tranny - A6 rear differential EUU or FVN (4.11) - bolts right on. - Move Allroad front flanges to S4 tranny Everything else stays the same and you can enjoy much better geared allroad. |
#4 |
subscribing to this. what is the estimated cost of this swap?
Two sedans and a station wagon... |
#5 |
2005 Audi AllroadJoin Date: Aug 2004
What about speedometer calibration? If the final drive ratio is different, it needs to be programmed into the cluster, no?
2005 AR 2.7 Black: GIAC tune, 710N, H-sport sway bars, Depo LED taillights, akebono pads delete Past Audis: 2001 A6 4.2 | 2001 A4 1.8T Quattro | 1993 100 CS Quattro | 1984 5000 CD turbo FWD |
#6 |
I have a rebuilt S4 tranny in my built 3L Tial 605 AR and I love it! I'm not sure that any speedo calibration was required but the gearing is definitely more road worthy and from what I have heard, brings the highway cruising RPM's down significantly. That being said, I think the TDI tranny might be even another step further in the right direction. Just my .02.
#7 |
Thanks for the feedback guys, I'm headed down to mass tomorrow morning with my f-350 to pick up some parts and will update then.
#8 |
If no changes are made to the engine, than swapping the allroad tranny for an S4 tranny would result in slower acceleration due to the higher gearing. The allroad has the low gearing not only for offroad use, but to move a heavier car with the same grunt as other Audi vehicles.
The main advantage of using the S4 tranny is the better gearing for highway cruising, to help get slightly better mpg's. It is possible to replace the 5th and/or 6th gear in the allroad tranny with S4 or TDI gears, to keep the same low gearing for acceleration while dropping the highway cruising RPM. Advanced Automotion is probably the best source for that.
2004 allroad 4.2 - Ebony Pearl Effect FBP - H-sport sway bars - Phatbox MP3 player - stock 18" wheels with Continental DWS tires - stock 17" wheels with Yokohama Geolandar tires - custom tow hitch |
#9 |
Great feedback guys, i agree without engine mods, it would result in slower acceleration. Fortunately the AR is getting a full stage 3 build. I went down and got an 6 speed A6 parts car with no drive train but with rear diff, and also all the brackets, which I need and the actual s4 6 speed and various other other Audi parts
, i'll toss some pics up when the truck is unloaded.
#10 | |
Sounds like a huge waste of money to me. I think you need to decide whether you wand a highway econobox or a very high performance wagon. JMO.
-Mike |
| Tags |
| 01e, 6th, advanced, allroad, automotion, gear, swap, transmission |
