#21 | |||
01 Pearl White A6 4.2 Quattro Sport, cold, everything except Nav. TEMPORARILY PISSED OFF WITH ITS FUEL BANKS LEAN ISSUES... |
#22 | |
#23 | |
#24 |
No update from OP?
#25 |
2002 Audi S6Join Date: Oct 2002
Which is why I said a competent Audi shop. One way to check for a bad caliper in ths case would have been to open te bleeder. If caliper releases it's not the caliper.
#26 |
![]() Join Date: Mar 2003
it goes away when braking and when coasting? What's left, "under acceleration" only? So it rattles when accelerating....hmmm, stress on driveline.... think think
Incidentally, my comment was not to you, it was to the guy who said locked brakes cna come from fludi contamination, in response to my post that it appeared to have been narrowed from rotors to caliper pins.....but now you say "no"
glenahan@vee-eff-email*dot*net |
#27 | |
the rotors are not an issue as they have been checked, also the caliper pins have been checked also not an issue. also, it makes the noise when driving or coasting, but the noise goes away under braking, just to clarify that. |
#28 |
2005 Audi AllroadJoin Date: Aug 2004
So did you check the power steering bolts yet?
#29 |
#30 |
The fluid was completely bled. Guy said it was contaminated. Cut the rotor, guy said the pads are fine, but they look crumbly and I dont think they are complete contact with the rotor at this point. Brake performance is fine right now.
I cant bring it to a Audi shop because I have zero money. I work for Big Blue, can barely make my mortgage. The ABS light is still on, the brake light is still flashing. Tried to get the vag-com to pull codes. I had to get a USB to serial adapter to connect as I have no computer with a serial port(traditional). Connecting to any module fails, except the radio. It connects fine to the radio module, which is of zero help. |
| Tags |
| a4, abs, b6, fire |
