#1 | ||
1967 Ford MustangMy Garage Join Date: Apr 2012
#2 | |
2012 Audi Q5My Garage Join Date: Mar 2005
http://www.ecstuning.com/Audi-All_Ro...r_Main/ES3114/ Last edited by ezveedub; 05-01-2012 at 03:41 PM. |
#3 | |
Before I consider myself doomed to the above process I have to ask if there any other way for coolant to get inside the bellhousing? Is there an opening in the bellhousing and a leak path from above that I could have missed? Thanks again. |
#4 |
Not really. That's why I said to make sure there is no leaks from the coolant pipe or anything attached to it above the transmission. Also make sure there is no coolant in the V-bank of the engine where the aux coolant pump is. If you pressurize the cooling system and check everything above, but coolant is only seen coming out at the bottom of the bellhousing, then it's the flange. I've seen it leak on 2.8 and 2.7Ts way back when the cars were under warranty. It happens rarely, but it does happen.
#5 |
if its coming from the rear water manifold to head orings, they leak right on top of the trans and can look just like its coming from the bellhousing.
1992 Audi 100 CS Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant 1998 Audi A4 quattro |
#6 |
Dont rule out the coolant bottle overflow leaking into that area. I had this happen once on an S4, so to be sure I moved the overflow tube to the driver side of the engine and then the coolant leak appeared there after a few days instead of around back of the engine / transmission. Its easy to give it a shot.
| Tags |
| 03, 100, 1992, 92, allroad, allroads, antifreeze, audi, audiworld, common, coolant, coolent, inside, leak, leaking, leaks, mysterious |
