#1 | ||
#2 |
2012 Audi Q5My Garage Join Date: Mar 2005
If it has an oil-to-water oil cooler, say on the oil filter housing where the oil filter is mounted to, replace that as the suspected cause. The engine oil pressure is higher than the coolant pressure and will most likely transfer into the cooling system when the engine is running.
#3 |
1994 Audi 90My Garage Join Date: Jan 2002
The 88 does have a oil cooler. If the seal breaks it will leak oil but not into the coolant, for that to happen internally the channels that direct the coolant over the fins would need to break.
I replaced mine a few years ago as one of the intake necks broke through and I was leaking coolant. I bought it from AZ for maybe $60. It could be the reason, maybe not. At 22 years old, if acidic coolant has been sitting in it as you mentioned the car sat for a few years it might be time to replace it. The aluminum is thin at the necks, if it were to break you would lose coolant quite fast if you were driving. Eliminate that chance from happening. Replace the O-ring as well, after 10 years they harden and are no longer round but flat,BTDT.
| Tags |
| 2001, 90, a4, antifreeze, audi, car, coolant, fine, great, oil, reservoir, runs |
