Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 04-30-2012, 11:25 PM   #1
crusininda944
Send a message via AIM to crusininda944
Default what to also do while servicing timing belt
Hello,
I'm new to driving my 99.5 A4 1.8TQM - I'm going to be getting the timing belt serviced this month with the kit from blauparts. In addition to the TB kit, I also saw their Valve Cover Cam Chain Tensioner Gasket Kit, of which I also plan to purchase and complete when the car is apart.
My question - is there anything else that is worthwhile doing while the car is disassembled? Should I purchase a head gasket & have them replace this also? Is there anything in particular other than the valve cover cam chain tensioner & tb kits that I should look at purchasing to ensure maximum reliablity?
Also, what about the turbo? Is this easily accessible and serviceable in addition to the timing belt? I was told by a previous mechanic that it's leaking oil - is this worth addressing now?
I'm looking to be as thorough as possible and am having trouble finding out which items I should include with this service.
Thanks in advance!
"Marijuana in its natural form is far safer than many foods we commonly consume."
- Administrative Law Judge Francis Young, DEA
You cannot help the poor by destroying the rich.
You cannot strengthen the weak by weakening the strong.
You cannot bring about prosperity by discouraging thrift.
You cannot lift the wage earner up by pulling the wage payer down.
You cannot further the brotherhood of man by inciting class hatred.
You cannot build character and courage by taking away men's initiative and independence.
You cannot help men permanently by doing for them what they could and should do for themselves.
- Abraham Lincoln
1996 A6Q - 197k
- 225/45/17 Bridgestone Potenza's
- ASA AR2 Rims
- Sport Steering Wheel
- Euro S6+ Tails
- 1800 watt stereo
- Alpine iDA-X100 Headunit & Sirius Satellite Radio
- Infinity Kappa Glass-Fiber Speakers
- Dual 12" Kenwood Subs
- Clearcorner sidemarkers
- (Borrowed) Golden Retriever to aid in sexing up the ladies
crusininda944 is offline   Reply With Quote
Old 05-01-2012, 07:58 AM   #2
turbo510
2007 Volkswagen Touareg
My Garage
Did you order the full Blau kit with water pump and thermostat? You should change those too (I have that kit being delivered this week). Head gasket can be ignored unless you have some reason to suspect it. You are also going to have the plugs out while doing the belt, might as well change those unless they are fairly fresh. Also the snub mount will be easy and cheap to change while in service position.
Take a good look at cooling hoses, motor mounts, and rubber ducting from air cleaner to the turbo, which sometimes develops cracks. Mechanical fan clutch would be easy to change at this time too, if it has quit working.
The turbo isn't much more serviceable while doing the timing belt, but an oil leak may be a hose or oil line connection issue rather than an actual turbo problem.
1996 Audi A4 2.8
1972 Datsun 510
turbo510 is offline   Reply With Quote
Old 05-01-2012, 09:43 AM   #3
4Driver4
Tech Guru
4Driver4's Avatar
Consider changing the plastic water outlet on the back of the head, along with the coolant temp sensor.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 05-01-2012, 12:06 PM   #4
Prospeeder
the turbos will ALWAYS look like there leaking alittle oil, nothing to worry about. i would just do the timing belt water pump idlers seals and drive belt.
1992 Audi 100 CS Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
1998 Audi A4 quattro
Prospeeder is offline   Reply With Quote
Old 05-01-2012, 12:21 PM   #5
4Driver4
Tech Guru
4Driver4's Avatar
Did you mean to respond to me or the OP?
4Driver4
Old 05-01-2012, 11:19 PM   #6
crusininda944
I am ordering the full timing kit from blauparts with water pump and thermostat:
http://www.blauparts.com/proddetail.asp?prod=GH21102-1A
Also, the valve cover cam chain tensioner gasket enhanced ultra kit
http://www.blauparts.com/proddetail.asp?prod=GF21005-2A
- The Fan Clutch pulley & fan clutch were both replaced today along with the accessory belt.
- I'll snag a coolant temp sensor from ECS since it's $5.
A few questions though -
1) What part exactly is the 'plastic water outlet on the back of the head?'
2) When you say plugs, you mean the sparkplugs? Because those are also on my list to change. Haven't been replaced for at least 30k.
3) In regard to the snub mount - is there only one of them? And would the upgraded APR one from ECS tuning be worth purchasing? They state it "enhances upshifting and downshifting, reduces driveline shock, & helps power transfer by taking up excess drivetrain slack"
Thanks for the advice on the turbo. My main concern & goal is to address anything that might be potentially catastrophic. Like I said, this is my first turbo car & I want to be as proactive as possible. My C4 A6 seems like a tank comparatively to my newer B5 A4. I just had my brakes/rotors done & upgraded, along with a couple of other small things & I want to ensure that once this TB service is complete, I'll have maximum peace of mind against any future unexpected repairs.
- Abraham Lincoln
1996 A6Q - 197k
- ASA AR2 Rims
- Euro S6+ Tails
- 1800 watt stereo
Old 05-02-2012, 07:27 AM   #7
turbo510
My Garage
4Driver4 referred to the part on the very back of the cylinder head, which is plastic, and includes the coolant temp sensor socket.
Yes, I did mean spark plugs. Speaking of plugs, I put a set of the cheapest Autolites from AutoZone while doing some troubleshooting a while back; they seem to work just as well as the expensive OEM NGKs, at least at the low-boost driving we do with the wagon.
I just installed an OEM-type snub mount (there is only one) and don't know about the APR version. I mentioned the motor mounts because they do break sometimes. One in the wagon was almost cracked through, and this is a mildly-driven wife's car.
1996 Audi A4 2.8
1972 Datsun 510
Old 05-02-2012, 09:20 AM   #8
Reggie
AudiWorld Expert
2011 Audi Q5
My Garage
Reggie's Avatar
Originally Posted by crusininda944 View Post
Hello,
Thanks in advance!
What are you using for instructions? Some people do a snub mount too.
Reggie is offline   Reply With Quote
Old 05-03-2012, 01:41 AM   #9
crusininda944
I've also found an upgraded intake manifold gasket via ecs tuning - does anyone know how easy this would be to access as well?
figures look pretty decent for a $55 upgrade
http://www.ecstuning.com/Audi-B5_A4-...Gasket/ES1394/
- Abraham Lincoln
1996 A6Q - 197k
- ASA AR2 Rims
- Euro S6+ Tails
- 1800 watt stereo
Old 05-03-2012, 02:58 AM   #10
4Driver4
Tech Guru
4Driver4's Avatar
Meh. Not worth the effort. Save your money.
4Driver4
a4, a6, audi, b5, belt, blauparts, easy, kit, replace, sensor, temperature, timing, transmission, working
