| A4 (B6 Platform) Discussion Discussion forum for the B6 Audi A4 produced from 2002-2005 |
#1 | ||
#2 |
I changed the ignition coils and spark plugs when the recall happened about 2 or 3 years ago. I also need an oil change and I will be doing that any day now.
#3 |
Also I changed the timing belt when I had 90,000 miles, I now have 156,000 miles.
#4 |
That sounds more like a vaccuum or intake leak.
#5 |
Sounds like a PCV issue. I had the exact same problems, misfire at idle along with all those misfire codes. Have a reach under and check all the pcv lines and hoses. Turns out the one connecting to the oil filter was disintegrating as when we pulled it off it literally crumbled.
#6 |
Sounds like a some sort of VAC leak, I agree with lyleswk.
Check your suction jet pump...(do a search for the item, because I don't have any photos) |
#7 |
Gentlemen,
Thank you for the replies. It was a vacuum leak. I had a mechanic replace the black plastic valve, cost me $180. I think I got off easy. Car runs like brand new. I hope my audi lasts forever. |
| Tags |
| 2002, a4, audi, car, check, engine, high, idle, light, lopove, rpm, rpms, shakes, shaking, stopped |
