Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B8 Platform) Discussion
A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5-present
Old 04-30-2012, 07:54 AM   #1
gravitycure
Default Maintenance
Hey. I have recently purchased an 09 A4. There does not seem to be a routine maintenance guide. Any suggestions on frequency of oil change and other needs?
.f.
gravitycure is offline   Reply With Quote
Old 04-30-2012, 09:40 AM   #2
gunsmoker
gunsmoker's Avatar
.f.
You can find that on audiusa.com. Oil changes are at 10k miles starting at 5k. Spark plugs are at 35k. I'm not planning to do anything else apart from occasional air filter checkups. I have a washable filter. If you feel like it, you can change the brake fluid every 2 years. I have done that on other cars, but haven't noticed a difference really.
2011 A4 2.0T Quattro Premium Plus, 6MT, 18" Sport Package, Dark Walnut Inlays, Silver/Light Grey, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs
gunsmoker is offline   Reply With Quote
Old 04-30-2012, 09:47 AM   #3
uberwgn
uberwgn's Avatar
F, welcome aboard! Here is the schedule/check list:
uberwgn is online now   Reply With Quote
Old 04-30-2012, 07:50 PM   #4
Moviela
2009 Audi A4
You really do need to flush the brake fluid every two years from date of manufacture.
Copper absorption in the brake fluid rises at a relativly constant rate and at 2 years it will start to increase corrsion of the PWM piston in the ABS unit. The loss of brake effectiveness is not only a safety problem, but can be expensive too.
Modern ABS fluids have two kinds of amine-based corrosion inhibitors but they change sides when copper levels rise they work to cause iron corrsion.
It really does not matter how much or how little you drive, it just needs changing every two years from when it was installed.
Moviela is offline   Reply With Quote
Old 05-01-2012, 02:23 AM   #5
gunsmoker
gunsmoker's Avatar
This can be used to tell if the copper level is high enough to require a fluid change:
http://www.ebay.com/itm/Phoenix-Syst..._Tools&vxp=mtr
Old 05-04-2012, 08:35 PM   #6
gravitycure
Thanks. Great chart.
a5, audi, maintenance
