#1 | ||
#2 |
Negative. I've not heard of this either. I'll have to look for this next time. What could the cause be? Did you take a photo you could post? Yes, I think the cams runs just in the alu. head and caps.
#3 |
Negative on the photo until i pull the valve covers to replace those. Unfortunately i can not find a part no. for these specific cam caps, both end caps i described have cracks. And spare cam caps have on the shelf also have cracks--albeit much smaller. The passenger side front i could blame on the wrong size cam seal, but the DS rear? Theres no seal there and it is cracked too. Im thinking this is stress related and due to poor design or not enough material on this cap. The v shaped caps are fine. Anyone putting some serious hp on the engine may have probs..
#4 |
1993 Audi 90My Garage Join Date: Oct 2008
what you are talking about is most likely just casting marks and not cracks, oil and dirt gets in them and makes it look like cracks
1993 Audi 90CS Quattro (loving it) *new front struts, 034 control arm bushings, tie rods. mount savers. B5 sport rear springs/socks, B5 sport swaybar, B5 upper a-arms, 034street density trans mounts,17" ASA, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel, aluminum subframe mounts) *replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch. 1975 VW bus (gone) 1973 VW Super Beetle (what was i thinking?) 1968 VW Bug (my pride and joy) *2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers 1991 GMC Sonoma RWD, manual, 4 banger (gone) 1979 Suzuki GS750EN with 31k original miles 1981 Suzuki GS750L (will be on a chopping block for a bobber) 1981 Yamaha XV920 1983 Yamaha XV750 (for g.f.) 1985 Dnepr MT10-36 (stolen) 1992 Dnepr MT11-32 (also stolen) |
| Tags |
| 1993, 90, a4, a8, audi, bearing, cam, cap, caps, diagnostic, face, number, part, quattro, tool, vr6 |
