Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 04-29-2012, 08:56 AM   #1
volvopentaman
1986 Volvo 340DL
My Garage
Send a message via MSN to volvopentaman
Default Service interval reset problem
I've got an interesting problem when trying to reset the service interval on my W12 -06.
It says i have a gateway coding problem, and won't let me do any coding to the instrument panel.
I can code the ECU, i can read and reset fault codes from all control units including the instrumet cluster
Any idea what's the problem?
I managed to reset the service interval a few months ago, but now it won't let me access the instrumet cluster coding with the guided SRI function.
volvopentaman is offline   Reply With Quote
Old 04-30-2012, 05:53 AM   #2
jakematic
2012 Audi A8L
jakematic's Avatar
Do you have a record of the coding for your CAN gateway module 19 ?
2012 A8L 4.2 Oolong/Titanium. Premium, LED, Driver assist, Rear seat comfort, Dual pane, Alcantara, Panorama
jakematic is offline   Reply With Quote
Old 04-30-2012, 06:48 AM   #3
volvopentaman
1986 Volvo 340DL
My Garage
No coding has been done to the can gateway between the two services.
The only coding i've done to the car is put on the battery meter, oil-leve-display for the MMI, and the engine-pre-heat option for the HVAC panel, shouldn't affect the can gateway in any way AFAIK, or could this be the issue?
Tough one of the control units report a coding failure, but as i remember, it reported it already before the last service reset.
I'll take a list of fault-codes for all control units and put it up.
Old 04-30-2012, 07:48 AM   #4
volvopentaman
1986 Volvo 340DL
My Garage
Took a DTC scan on the CAN gateway (19).
Three trouble codes, worng codin was one, the second was media-player position 2 no contact, and then a third of a broken optical bus.
And then no contact to the instrumet cluster i got from the central electronics module... this could be the culprit?
I've tried everything, disconnected the battery, fuses for the cluste and so on...
Wonder what causes this....
And another thing i noticed, the car is draining the battery faster than my charger can supply (3,6A)...
Didn't manage to get all the DTC:s here, but most of them are totally irrelevant...
Old 04-30-2012, 11:42 AM   #5
jakematic
2012 Audi A8L
jakematic's Avatar
Originally Posted by volvopentaman View Post
.... and then a third of a broken optical bus.
I'm thinking the broken optical bus is a big part of the problem.
Might explain the no contact....
Old 05-03-2012, 11:15 PM   #6
volvopentaman
1986 Volvo 340DL
My Garage
But i don't think the instrumet cluster, ECU nor the can gateway are part of an optical bus. If i have understood right, the optical bus is only for the entertainment system (MOST bus).
I put the coding back for the MMI system as it was, but no help.
I could recode the CAN gateway, if I only had the coding list for it. Ross tech has lists for the A8 4E (and many other cars), but not for the can gateway...
Old 05-03-2012, 11:20 PM   #7
volvopentaman
1986 Volvo 340DL
My Garage
http://wiki.ross-tech.com/wiki/index.php/Audi_A8/S8_(4E)
Old 05-04-2012, 04:59 AM   #8
jakematic
2012 Audi A8L
jakematic's Avatar
First place I looked when I saw your post.
Was hoping that there might be some hints in VCDS/VAG tool...
Old 05-04-2012, 02:06 PM   #9
volvopentaman
1986 Volvo 340DL
My Garage
I've also got the factory service manual (Audi Service Manual v10) for all audi cars, and access to EVERYTHING a audi workshop has, but just don't know how to find the gateway coding stuff...
Old 05-06-2012, 09:53 AM   #10
volvopentaman
1986 Volvo 340DL
My Garage
Here's a full scan of the car's faultcodes.
The problems are probably in the gateway unit that it can't contact the instrumet cluster.
The question is, WHY can I reset faultcodes, but can't reset the serice (doesn't both functions require communication via the CAN gateway)?
VAS-PC
Self-Diagnosis protocol
06.05.2012 20:39
1001.01 - Check DTC memory - Entire system
69 - Trailer function
4E0910383B
ANHAENGERELEKTR 003 --- 0040
Coding 1
Dealership number 2313
4E0907383B
1 Malfunction detected
2564 11
Bulb for left taillamp on trailer
Open circuit
static
Environmental conditions:
01111011 3 1 207 0212880 0 19.08.11 19:12:00
15 - Airbag
4E0910655D
Airbag 9.41 H12 H12 3610
Coding 430707
4E0959655H
0 Malfunction detected
61 - Battery regulation
4E0910181C
ENERGIEMANAGER H12 000 0480
Coding
Dealership number 11400
4E0915181C
4E0915105A von VA0 3810093046 ---
Coding long
4 Malfunction detected
2273 0
Static current stage 2
tbd
Intermittent
00100000 7 6 - 0228018 0 29.04.12 23:47:45
2276 0
Static current stage 5
tbd
static
01100000 7 6 - 0228018 0 30.04.12 00:37:29
2274 0
Static current stage 3
tbd
Intermittent
00100000 7 5 - 0228018 0 30.04.12 00:37:39
2277 0
Static current stage 6
tbd
Intermittent
00100000 7 4 - 0228018 0 30.04.12 00:37:49
38 - Roof electronics
4E0910135A
Dachknoten D3 H02 --- 0090
Coding 3238
4E0907135A
03 - Brake electronics
4E0910517C
ESP 5.7 allrad H44 --- 0330
Coding 7637
4E0614517BD
1826 0
Steering Angle Sensor -G85-, voltage supply terminal 30
tbd
Intermittent
Error without environment conditions
53 - Parking brake
4E0910801C
EPB A32C0220 H02 2C0 0220
Coding 631
4E0907801A
76 - Parking assistance
4E0910283C
Parkhilfe 8-Kan H12 H12 0030
Coding 211108
Dealership number 131071
4E0919283C
05 - Access and start authorization
4E0910131
FBS AUDID3 H07 604 0160
Coding 263168
Dealership number 2311
4E0909131G
XXXXXXXXXXX ELV --- XXXX
Coding
Dealership number 0
25 - Immobilizer
4E0910131
Coding 263168
4E0909131G
Coding
Dealership number 0
02 - Gearbox electronics
4E1910156G
AG6 09E 6,0L4V RdW H01 0060
Coding 1
09E927156B
09 - Electronic central electronics
4E0910279L
ILM Fahrer H12 --- 0210
Coding 133122
4E1955113B
4E1910113B Wischer WWS D3 H50 --- 0400
Coding 34
4E0955559A
4E0910557 REGENLICHTSENSORH10 --- 0050
Coding 141886
1317 4
Instrument cluster control module -J285
No signal/communication
Intermittent
00100100 2 1 144 0228017 0 29.04.12 17:08:20
4F - Electronic central electronics systems 2
4E0910280A
ILM Beifahrer H11 0070
Coding 10101
4E0907280A
46 - Convenience system central module
4E0910289B
Komfortgeraet H05 100 0010
Coding 4728
4E0907289
4E0910853 Heckdeckel H06 --- 0060
Coding
Dealership number 0
4E0907719 Neigungssensor H04 --- 0020
Coding
Dealership number 0
17 - Instrument cluster
4E0910900S
KOMBIINSTR. VDO H71 2 0400
Coding 2
Dealership number 78654
4E0920900S
08 - Air conditioner/heater electronics
4E0910043B
KLIMAAUTOMAT 016 000 0400
Coding 78047
4E0820043D
4E0910133 FHS H02 --- 0040
Coding
Dealership number 0
8E0907133A
3 Malfunction detected
1593 11
Heated windshield -Z2
Open circuit
static
01101011 3 1 76 0199916 0 10.01.11 10:01:54
18.0 °C
65 12
Left Rear Footwell Heater -Z42-
Electrical malfunction in circuit
static
01101100 3 86 93 0224564 0 11.02.12 20:59:41
14.1 V
66 4
Right Rear Footwell Heater -Z43-
static
01100100 3 5 93 0199916 0 10.01.11 10:01:55
12.0 V
28 - Rear air conditioning control
4E0910158
KLIMA-STG. FOND 015 000 0220
Coding 0
Dealership number 0
4E0919158A
34 - Level control system
4E0910553H
LUFTFDR.-CDC H06 --- 4480
Coding 15520
4E0907553F
55 - Automatic vertical headlight aim control
4F0910357C
AFS 1 H01 000 0030
Coding 18
4F0907357C
4F0941329B AFS-Modul links H02 --- 0020
Coding
Dealership number 0
4F0941329B
4F0941329B AFS-Modul rechtsH02 --- 0020
Coding
Dealership number 0
4F0941329B
01 - Engine electronics
4E0910018
6.0L W12/4V G 000 0050
Coding 11773
4E0906018
11 Malfunction detected
19061 4
O2 Sensor Pumping Current Trim Circuit/Open Bank 2, Sensor 1
Intermittent
18107 8
Databus drivetrain
missing message from Steering Column Electronics
Intermittent
18043 8
Databus drivetrain
missing message from A/C control module
Intermittent
18347 8
Databus drivetrain
missing message from access start authorization ctrl module
Intermittent
18058 8
Databus drivetrain
missing message from instrument cluster
Intermittent
29698 8
Central control module for comfort system -J393-
Read out DTC
Intermittent
18010 2
Power supply terminal 30
Voltage too low
Intermittent
18061 8
Read DTC memory of
ABS CM
Intermittent
17498 1
Bank2, mixture adaptation range 2
Lean limit not reached
static
17560 1
Bank1, mixture adaptation, range 2
static
18331 8
Check DTC memory of
Engine Control Module (ECM) 2
static
11 - Engine electronics 2
4E0910018
Coding 11773
4E0906018
8 Malfunction detected
18043 8
Databus drivetrain
Intermittent
18347 8
Databus drivetrain
Intermittent
18058 8
Databus drivetrain
Intermittent
29698 8
Read out DTC
Intermittent
18010 2
Voltage too low
Intermittent
18061 8
Read DTC memory of
ABS CM
Intermittent
17490 1
Exhaust bank3, mixture adaptation range 2
static
17494 1
Exhaust bank4, mixture adaptation range 2
static
18 - Auxiliary/parking heater
4E0910105A
Heizgeraet H07 000 0100
Coding 111
Dealership number 0
4E0265081J *
2 Malfunction detected
664 2
Fuel gauge
Lower limit not reached
Intermittent
1444 0
Low voltage cut-out (automatic)
tbd
Intermittent
16 - Steering column electronics
4E0910549A
J0527 H01 0310
Coding 12341
4E0953549B
XXXXXXXXXXX E0221 H07 --- 0090
Coding
Dealership number 0
36 - Driver’s seat adjustment
4E0910760D
Sitzmemory FS H01 000 0010
Coding 4063842
Dealership number 0
4E0959760B
06 - Passenger side seat adjustment
4E0910760D
Sitzmemory BFS H01 000 0010
Coding 4063840
Dealership number 0
4E0959760B
42 - Driver door electronics
4E1910802B
T?rsteuer.FS BRM003 --- 0090
Coding 32749
4E1959801B
52 - Passenger door electronics
4E1910802B
T?rsteuer.BF BRM003 --- 0090
Coding 32749
4E1959802B
2111 5
Motor for window regulator
no or incorrect basic setting/adaptation
Intermittent
00100101 3 1 122 0223824 0 27.01.12 20:35:26
62 - Left rear door electronics
4E0910802A
T?rsteuer.HL BRM003 --- 0090
Coding 32749
4E0959801C
72 - Right rear door electronics
4E0910802A
T?rsteuer.HR BRM003 --- 0090
Coding 32749
4E0959802C
09, 1317, 2005, a4, a8, audi, functions, guided, interval, j285, pc, reset, ross, service, tech, vas
