| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#1 | ||
#2 |
2005 Audi A8Join Date: Nov 2010
#3 |
#4 |
No harm done. We can't have too many information.
#5 |
Gruven product is good. Just need to keep an eye on the shaft operation once installed.
Reason being is that the links are the weak point if failure of the shafts or butterflies occurs. But, sometimes the links just age and become brittle then fail, like in my case. Before you fit the links, manually rotate each of the arms to check of the shafts 'stick' or click or are very hard to move. If so, DO NOT INSTALL THE NEW LINKS. Rip the intake off and refurbish / clean out the intake and check why the shafts are not moving freely. Repair then fit the links. Cheers
A8 4.2 S
#6 |
2004 Audi A8Join Date: Jan 2012
Thanks for all the tips guys. I checked mine today too, meant to do it when the most recent thread came up that mishear posted but forgot. Both shafts on my 2004 are broken. I ordered the gruvenparts shafts today.
Question, is there a trick to getting the plastic shafts off, or they just pop right off with enough pressure? Thanks. |
#7 | |
:-) The first thing I did was make sure the shafts where not binding or stuck, both move just fine. I think I am good, just a victim of the plastic failing. |
#8 | |
#9 | |
A8 4.2 S
#10 |
What size did you guys order? Going to check mines later but want order them now. Had mines for almost 5 years and I'm pretty sure one or both might be broken.
04 Audi A8 w/20-275/35/20 rubber and all the options 04 FX35 AWD sport "Our perception and attitude toward any situation will determine the outcome" |
| Tags |
| 04, 2004, a8, a8l, actuator, acutuator, arms, audi, audiworld, broken, info, intake, links, vacuum, valve |
