| TT (Mk1) Discussion Discussion forum for the Mk1 Audi TT Coupe & Roadster produced from 2000-2006 |
#1 | ||
#2 |
1991 BMW 8-SeriesMy Garage Join Date: Mar 2012
If you have to ask these questions, you are heading for disaster. This is one job you should not try unless you have done it before with somebody else who knows what they are doing. One small mistake will destroy your engine. Trust me. I destroyed the engine on my 1985 Maserati Biturbo by trying to replace the water pump myself. I had the timing belt off by one tooth, and it was costly. I do almost all the maintenance on my TT myself, but last month when I needed timing belt service, I took it to the pros. This is not the place to save money. Ciao!
2002 Audi TT hardtop w/GIAC 1991 BMW 850ia w/Conforti |
#3 |
So I replaced my timing belt. It took about 10 hours but everything went well. The old timing belt looked OK but the old tensioner was worn. The transmission flywheel inspection hole is above the transmission on the driver's side of the engine. I supported the engine with an engine support bar linked to a point on the engine. However, when I had to replace the engine mount I had to jack the engine from underneath to get the alignment correct.
Overall not a bad way to spend a day. |
#4 | |
So, what's next on your TT list? |
#5 |
After the timing belt, I changed the oil, changed the haldex oil and filter, and replaced the brake fluid.
Next up is new brake rotors and pads. Should be a piece of cake after the timing belt. I love my little rat car. |
| Tags |
| 2002, a4, audi, audiworld, belt, diy, fly, flywheel, hole, inspection, timing, transmission, tt, wheel |
