Old 04-28-2012, 01:24 PM   #1
5000turbo
5000turbo's Avatar
Default 5th gear boost surge 12psi-15psi
it holds at 18 1-3 15psi in 4th and then flexs between 12psi and 15psi in 5th, i'm not quite sure what it is... I don't think its a boost leak so idk? any ideas?
P&P K24 Turbo
ARP Headstuds
1.9 bar Wastegate Spring
3“ custom down pipe
3" Magnaflow
ABT cam
Custom Intercooler
MSD Ignition
Megasquirt Fuel Injection MAC 11C 2.5 bar map
Greddy Profect B boost controller (18 psi)
Water-Meth Injection
Bilstein HD Shocks and H&R Springs
Rebuilt Front calipers, Hawks alround,SS Lines
V- 8 Master Cyl and rear disc upgrade
93 V-8 Ft sway bar
5000turbo is offline   Reply With Quote
Old 05-06-2012, 05:17 AM   #2
88A5TQ
1988 Audi 5000
88A5TQ's Avatar
Send a message via ICQ to 88A5TQ
Hey. I don't know squat about boost controllers but maybe you can set different values for different gears but I doubt it. I would start by checking all vacuum lines to and from the controller and wastegate and the wastegate diaphragm. Also maybe give greddy customer service a call. Another consideration might be that the Ecu is limiting boost somehow through the controller (idk?) because of a rise in intake/coolant temps. Does it behave like this even with the water/meth setup replenished?
Last recommendation: join motorgeek and repost these questions. EFI is the life-force for the majority of vehicles over there.
1988 Audi 5000 CS TQ
2.5" cat-back, K&N CAI, TAP, HDI EBC 18 psi, 034 shifter, AEM W/M, black leather/suede interior
1987 5000 tq parts car
88A5TQ is offline   Reply With Quote
Old 05-07-2012, 11:37 AM   #3
AudiQ5sleeper
Vacuum leak most likely. but use a fog machine to find that leak.
AudiQ5sleeper is offline   Reply With Quote
Old 05-12-2012, 08:12 AM   #4
5000turbo
5000turbo's Avatar
There is a hose that connects from the intercooler piping to the turbo inlet that is kinked.... possible issue/>
P&P K24 Turbo
ARP Headstuds
3“ custom down pipe
3" Magnaflow
ABT cam
Custom Intercooler
MSD Ignition
93 V-8 Ft sway bar
