| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#11 | |||
#12 |
Do you actually feel the car surging (like its engine braking) or do only see the revs oscillating?
A8 4.2 S
#13 |
What code was there when you checked?
04 Audi A8 w/20-275/35/20 rubber and all the options 04 FX35 AWD sport "Our perception and attitude toward any situation will determine the outcome" |
#14 |
2005 Audi A8Join Date: Dec 2011
#15 |
2007 Audi A8My Garage Join Date: Jan 2010
The codes I got from the OBDII sensor were
"Bank 2 system too lean" and "Bank 1 system too rich" When I looked them up they both seemed to reference a loose vacuum hose or a faulty MAF sensor. I should know by tonight what the problem is. There isn't any odd noises coming from the rear of the car where the fuel pump's are so that is why I didn't suspect that at all.
2007 A8L 6.0L W12 Fully loaded every option Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. 2005 A8 4.2L w/ all packages. Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. Popular Topics & Help for Noobies: Oil Change Procedure Disable TPMS System AMI Installation AMI Update (Phone not pairing) Remote Window Control Enable Hidden Menu & Enable Battery Meter Fog Light Replacement City Light Bulb Replacement Door, Trunk, & Glove Box LED Change Cabin Air Filter Change Maintenance & Common Problems |
#16 |
Senior Member
those are the standard vacuum hose codes, from prior C5 4.2 direct experience.
If you aren't familiar w/ it, notice contrary to perhaps some sense you get from the board, these kinds of codes don't point right at the bad part, but require the outside knowledge/experience set of what they tend to be associated with. Anyway, I stand by my first suggestion given the rougher cold run and then the CEL, now w/ the confirming codes. Dig into all vacuum lines. Or yes, could possibly be MAF. If you or prior owner ever ran a K&N filter, really could be an MAF. Otherwise I would start w/ the $10 vacuum hose stuff instead of the multihundred $ MAF.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#17 | |
I know you don't have codes for it, but it's not O2 sensors is it? I think you have lots of good suggestions on here before going for high $$ stuff... difficult to diagnose from afar, but much pf it makes sense. Too bad you're not a little closer, you'd be welcome to use my VCDS.
K9 Quote:
#18 |
The codes below are what happened when I needed to replace the Fuel Pump AND Oxygen Sensor in front of CAT. I also had codes for misfires. Run VCDS and you will be able to tell what might be going on.
Address 01: Engine Labels: 077-910-560-BFM.lbl Control Module Part Number: 4E0 910 560 J HW: 4E0 907 560 4 Faults Found: 17538 - Fuel Trim; Bank 2 (Mult) P1130 - 001 - System too Lean 16558 - Fuel Trim; Bank 2 P0174 - 001 - System Too Lean - MIL ON 17536 - Fuel Trim; Bank 1 (Mult) P1128 - 001 - System too Lean 16555 - Fuel Trim; Bank 1 P0171 - 001 - System Too Lean Readiness: 0000 0000 Last edited by 05SilverA8; 05-02-2012 at 08:36 AM. |
#19 |
Well guys found the culprit. Thank you all for your posts.
The main intake slipped off and was about 60% disconnected from the engine. Reason I didn't spot it/see it fully was because of all the other vacuum and hoses that are above the connection point. Once I removed the top part of the air box, the MAF sensor, and the vacuum tube, I was able to see it disconnected. Cleared the engine code and everything runs perfect now ![]() Case closed!
#20 | |
THREAD CLOSED!!!
![]() K9 Quote:
| Tags |
| 05, 42, 73, a8, audi, bad, d3, engine, idle, p0171, p0174, p1128, p1130, rough, surging, vibration, vw |
