| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#1 | ||
2007 Audi A8My Garage Join Date: Jan 2010
2007 A8L 6.0L W12 Fully loaded every option Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. 2005 A8 4.2L w/ all packages. Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. Popular Topics & Help for Noobies: Oil Change Procedure Disable TPMS System AMI Installation AMI Update (Phone not pairing) Remote Window Control Enable Hidden Menu & Enable Battery Meter Fog Light Replacement City Light Bulb Replacement Door, Trunk, & Glove Box LED Change Cabin Air Filter Change Maintenance & Common Problems |
#2 |
I imagine you have checked the fault codes by now. Whenever I've had an Idle stabilizer Valve go bad on a VW or Audi engine; the idle varied by800-1000 RPM's although this was on 4 & 5 cylinder engines with one ISV.
#3 |
Well I don't have a vag-com and not sure if a normal reader can read the engine codes, I'm sure it can. It could possibly be the large hose that is north of the MAF sensor, might be slightly disconnected on the back of the engine, as I can somewhat hear a sucking noise from air. Will check that out when I get some time.
#4 |
Senior Member
Would be the obvious--and cheap--place to start. You mention the main intake tubing/clamps in the first reply, so of course check that for starters.
Look over all the vacuum tubing, from my C5 (A6) 4.2 experience especially. Often the small (3mm) tubing. If they are still using the cloth covered (junk) tubing on the 4.2's like they were in 2000 to give it that VW Germanic look, head to the nearest NAPA store and buy 10-15 feet of quality tubing off of a reel. My C5 experience is it started failing in warranty and then continued until I replaced every last bit of it. Particularly any of the lines under any center intake manifold cover and behind the motor; they get really heat soaked, brittle and then crack. The most problematic ones from my C5 4.2 have been under the center cover that goes to some kind of switched valve, and another two that drop down in the back of the motor and relate to the air injection system. That system overlaps w/ cold idle so could fit your symptoms. Typically these vacuum hose failures did generate a bit of engine vibration on my A6, and indeed then the CEL. Since I did the NAPA quality hose change over, end of subsequent similar problems on my C5 4.2.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#5 |
2005 Audi A8Join Date: Dec 2011
... can chain guides? Also, i had similar symptoms on an old Volvo 760 Turbo years ago, turned out to be air flow meter. Just a thought...
K9 |
#6 |
Is it possible to use a standard car scanner to pull the CEL code? My friend has one that I could use. I dont think I need the vag-com in order to pull it do I?
#7 |
Senior Member
vacuum is pretty obvious, parts are really cheap and you say you thought you heard some air leaking.
Check it the old way in 10% of the time it will take to figure out codes. Just a thought.
#8 | |
I'm really inclined to agree with MP4.2+6.0 about vacuum issues though. If the "large hose North of the MAF sensor" you are referring to is the main intake to the throttle body, that would also be a possible culprit. The engine would be sucking un-metered air and that would definitely cause a surge. Otherwise, the Idle Air Speed Motor (the term I'm used to ) would be my next guess. This would be verifiable with an ODBII scanner. I suppose a filthy throttle body with a clogged (or nearly clogged) Minimum Air Passage could go along with this.Carry on...
2005 A8L 4.2 Silver on Black Leather / 5K range HID Headlamps / Fog Lamp Conversion to 3K range HIDs / Interior LED Conversion / Multiple VAG changes to suit (more coming, as nuggets are uncovered) / 19X8.5 Turbines with Conti DWS rubber / AMI Upgrade / Parktronic upgrade "The computer should work for you, not the other way around."
#9 |
2012 Audi A8LJoin Date: Feb 2011
While I can't put my mouse on the exact posts, I've read about this before.
IIRC after checking vacuum and MAF it usualy turned out to be TBA and/or throttle body cleaning fixed it. Code(s) will probably help narrow it down. Here is one post I found: Cold start idle bounce
2012 A8L 4.2 Oolong/Titanium. Premium, LED, Driver assist, Rear seat comfort, Dual pane, Alcantara, Panorama ![]()
#10 |
Well taking it to my mechanic today. At the dealer right now for a free vehicle service inspection, although I doubt they will even scan the code for me. Greedy bastards. Regardless, I will have it with my mechanic today and he will poke around and see what he can come up with. I checked all the hoses I could get to, and didn't see anything out of the ordinary. On my way to the dealership the car actually turned off while driving it, had to pull over and restart it to continue. Will keep you guys posted on what it comes out to be.
| Tags |
| 05, 42, 73, a8, audi, bad, d3, engine, idle, p0171, p0174, p1128, p1130, rough, surging, vibration, vw |
