Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 04-27-2012, 10:18 AM   #1
Honest
Default A4 1999 failed emisson test and running rough
Hi guys,
My car failed emission test and is running really rough, no power in any gears, very diffcult to go up hills.
I am getting the following codes:
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
31-10 - Open or Short to Ground - Intermittent
00523 - Intake Air Temp Sensor (G42)
30-10 - Open or Short to B+ - Intermittent
00537 - Lambda (Oxygen Sensor) Regulation
19-10 - Lower Limit - Intermittent
So far I have changed the CAT and Lambda sensor before the CAT.
I also installed a secondhand MAF a few months ago and changed the plug's about 4 weeks before the problem started.
Please help.
Honest is offline   Reply With Quote
Old 04-28-2012, 06:36 AM   #2
turbo510
2007 Volkswagen Touareg
My Garage
Have you tried running with the MAF sensor disconnected?
1996 Audi A4 2.8
1972 Datsun 510
turbo510 is offline   Reply With Quote
Old 04-30-2012, 07:05 AM   #3
Honest
Default MAF Cleaned
Thanks for your help turbo.
I have cleaned the MAF and the first 3 codes have now gone. Car is still running rough and I think it will still fail emission.
I now get this code
00525 - Oxygen (Lambda) Sensor (G39): Signal too Low
Could it be that my new Lamdba sensor is faulty?
This guy has the same problem as me, but no one has posted a solution.
http://forums.vwvortex.com/showthrea...ensor-problems
Old 05-05-2012, 12:17 PM   #4
mime651752
have you tested the O2 sensor yet? If its not bouncing below 200mv and above 800mv the sensor could be "lazy"=bad. Also obvious stuff like fouled plugs could cause a rough idle.
mime651752 is offline   Reply With Quote
Old 07-23-2012, 05:59 AM   #5
Honest
Default Does anyone have any ideas yet for my problem above?
My Lambda sensor is an aftermarket part from Euro Parts, I have tried two replacement parts from there but still have same problem.
It is defiantly not a bosch, Ngk or Denso part. Can’t remember the name.
Should I buy a genuine one from Audi.
Please help my car has been sat on my drive for months and I do not want to have to scrap my car, if it is just because of Lambda sensor or a minor part.
I have had the car for 7 years now and before the MOT it was very reliable.
Old 07-23-2012, 06:52 AM   #6
4Driver4
Tech Guru
4Driver4's Avatar
Clear the codes, drive car, post new codes.
4Driver4
"Never give up the throttle until the bitter end." -RC
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
00537, 1999, 28, 99, a4, audi, bad, codes, emissions, lamda, limit, lower, o2, oxygen, recall, rough, running, runs, sensor
