Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B8 Platform) Discussion
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present
Old 04-26-2012, 04:21 PM   #1
Jeffc
Default USB Drives with AMI
I bought a AMI-USB interface cable for $14 on Amazon. Not bad considering ECS wants $75. I plugged in a 32gig USB2 thumb drive and the music plays and sounds great. Plugged in a 500gig USB3 drive with 80gig of music on it and the MMI says it does not recognize the device. Is the drive too large or is the MMI not compatible with USB3?
Jeffc is offline   Reply With Quote
Old 04-27-2012, 03:02 AM   #2
Pyro451
2012 Audi S4
Pyro451's Avatar
The larger drive probably needs more power than the interface delivers.
There is probably a list somewhere of low power usb drives that will work.
2012 S4 Prestige | Monsoon Grey | Black/Magma Silk Nappa Leather | NAV/3GMMI | Sport Diff | SS Inlays | S-Tronic | Side Assist | Advanced Key | Backup Camera | Red Supercharged Badges | A&A LED Light Kit | STiR+ | LI Dual | Various VAG-COM mods | HEX-USB+CAN VAG-COM Cable
Pyro451 is offline   Reply With Quote
Old 04-27-2012, 06:05 AM   #3
Jeffc
That probably eliminates a USB hard drive and puts me back to using a USB flash drive. They top out at 64gig. Too bad, I was hoping to put up to 100gig of music onboard. I guess I can split genres between the SD cards and the usb drive.
Thanks for the info.
Old 04-27-2012, 07:32 AM   #4
Jeffc
I did some more experimenting. The MMI manual says there is a file limit of 4000, so I deleted all but about 20 files. No dice. Also reformatted from NTFS to exFat. No change.
I question whether power consumption is the problem since the portable USB3 drive is backward compatible to USB2 @ 500ma, which the MMI supports. Unfortunately, I don't have a USB3 flash drive to experiment with or I could confirm whether the problem is USB3 or power draw.
Old 04-27-2012, 09:48 AM   #5
Stereodude
Probably needs to be FAT or FAT32.
Stereodude is offline   Reply With Quote
Old 04-27-2012, 11:11 AM   #6
lodaka
I vote for power draw, considering that it has mechanical moving parts, probably requiring a bit more juice.
lodaka is offline   Reply With Quote
Old 04-27-2012, 02:29 PM   #7
Jeffc
I tried reformatting as exFAT and then FAT32. No go.
Old 04-30-2012, 01:59 PM   #8
Carbines
From just reading the few posts above, I'd say that the power requirement is probably what's at the root of the issue.
A pricey option *might* be an SSD drive mounted in a portable enclosure. I like the acomdata branded enclosures (available at amazon) for laptop-sized drives (2.5"). The SSD drive will require less power over the USB cable, and may work. Best idea would be try to find a friend to try his/hers SSD drive before you spend decent $$ on a new SSD just for the car.
Carbines is offline   Reply With Quote
Old 04-30-2012, 04:25 PM   #9
DrGP
DrGP's Avatar
I wish that I understood what you guys were talking about!
DrGP is offline   Reply With Quote
Old 04-30-2012, 05:01 PM   #10
Stereodude
It might also be that the drive + enclosure isn't a pure USB mass storage device, but instead some sort of combo device due to the enclosure which causes the MMI to not support it.
112, 160gb, 2012, ami, audi, card, classic, exfat, ipod, mmi, s4, sdhc, usb
