#11 | ||
Tech Guru
![]() Join Date: Oct 2002
4Driver4 "Never give up the throttle until the bitter end." -RC 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 2003 Mini Cooper S (Fun!) 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata SSB: track beotch 2003 GMC Yukon Denali XL: the anti-earth 2004 Dodge Dakota: hey, at least it's stick and 4x4 |
#12 |
![]() Join Date: Mar 2003
Let's look at this terminology two ways:
1. in the OP's content, really, ti doesn't matter. He intention was about the durability of hydraulic shocks. Since 99% of what people see are packaged within struts, the term is often (mis) used. 2. Are ours in fact struts? The definition of a Macpherson strut is as follows: "The MacPherson strut is a type of car suspension system which uses the axis of a telescopic damper as the upper steering pivot. It is widely used in modern vehicles and named after Earle S. MacPherson, who developed the design." In our cars, the upright holds the integral hub, and pivots on a derived pivot point, not a single kingpin/etc. I dont believe the upper attachment point is one of the steering pivots. Correct me if you nwo better, and thus, they are not. However, if you go to section 2-19 in Bentley, it labels the shock and spring assembly "strut". So that' the designation :-) The egocentricity (coli-over) aspect that Sloop brought up is totally irrelevant to the design. You could have a torsion bar, an air bag, or mag lev and it could meet the design definition. Grant
glenahan@vee-eff-email*dot*net |
#13 | ||
Tech Guru
Agreed. But the discussion really should use the correct terms.
I apologize if I derailed the OP. This is, however, one of my pet peeves.
#14 |
In many ways, mine too, along with "coil-over".
c ya G
#15 |
Tech Guru
LOL.
Well played.
#16 |
All I was asking if the group felt the front shocks really go in these cars or could it be the control arms. Dealer told me that the shocks don't go in 100000 miles in these cars. Just wondering if it could be the control arms giving me a wobble when I hit a bump. No noise, I don't lose control. Been under the car checking control arms. Everything seems fine but sometimes it's hard to tell when the weight is still on the suspension. Can you get a wobble with a bad control arm? Lower front holds the shock so I think you can.
2007 Q7 3.6 Premium 2003 A6 3.0 1980 MGB Limited 1959 Austin Healey 100-6 (under restoration) 2005 Ford Escape - Daughters |
#17 |
i answered your question below, long long ago.
I'll do it again. The shocks are more durable than most in these cars, but all shocks deteriorate, and it is gradual. The shocks don't locate the hub so it cant create wobble. It can begin to oscillate up and down, or even near rattle. If the hub is wobbling about its virtual kingpin, a control link must be bad. They can and do fail at both ends - one of the many ball joints (usually they get noisy first) or the rubber bushing at the other end. Check for play with a pry bar or even rock the wheel. You can se it done if you google "audi control arm test" or somesuch. G
#18 |
2005 Audi AllroadJoin Date: Aug 2004
Some owners replace at around 100K miles because it "feels" worn to them.
I don't subscribe to such thinking. If it isn't broken, it isn't broken. There are many Audis with over 200K miles on original shocks. Not to say that some don't wear out sooner, but one should not "expect" it to go. If anything, Audi shocks are more durable than many other manufacturers'. |
#19 |
2002 Audi S6Join Date: Oct 2002
Yes, but, 'ain't broken' covers a lot of territory. Weak shocks allow suspension to bottom out and otherwise beat the heck out of balljoints and bushings as well as reduce handling on rougher roads.
It's the old pay me now or pay me later...$600 worth of shocks may save $4K worth of end suspension rebuild. |
