Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » RS4 (B7 Platform) Discussion
Old 04-26-2012, 11:57 AM   #1
DrivingFool
DrivingFool's Avatar
Default Replacing brake light bulb
Any tips on replacing a brake light bulb?
Thanks and happy driving all. Last week took a speed run to the midwest (900 miles one way) and back and enjoyed it thoroughly... just not warm enough to put the top down!
DrivinFool
2008 Black on Black RS4 Cabriolet
DrivingFool is offline   Reply With Quote
Old 04-29-2012, 12:01 PM   #2
A4Audi4Fun
2008 Audi A4
Not sure if it's the same for a convertible - open the trunk and look at the inside lining error close to where the brake light housing area. There's likely a little round cap thing showing in the liner. Lift off with a small screwdriver. On the B6 & B7 sedans, you lift up that lining cap to expose a nut and bolt assemblt that attaches to the whole rear taillight assembly; the nut portion might be surrounded by plastic but look closely. Once you undo the nut, the whole taillight assembly should pull out from the vehicle body. Unclip the harness and then disassemble the housing with the tab clips there and replace the bulb. Reverse the procedure to put everything back together.
(CDN - Special Edition 2008 B7 Avant 2.0T S-Line Dolphin Gray 6MTQS)
A4Audi4Fun is offline   Reply With Quote
Old 04-29-2012, 06:52 PM   #3
DrivingFool
Thanks very much - I appreciate the reply.
DrivinFool
Old 04-30-2012, 09:50 AM   #4
FooFighterRS4
I had to replace mine a few months back. The bulb was around $5 from the dealer. The lining had a plastic screw and the entire tail light slid out. Then it was like a regular light bulb. The hardest part was aligning the liner. Took less than 15 minutes.
FooFighterRS4 is offline   Reply With Quote
Old 05-01-2012, 08:22 AM   #5
DrivingFool
Default Replacing Brake light bulb
Thanks for the reply! I'll give it a shot. - DF
DrivinFool
Old 06-04-2012, 02:20 PM   #6
Weaktor
2007 Audi RS4
I have a concern about changing the passenger side brake light. Once i remove the cap, there is a plastic piece blocking access to the bolt assembly. I believe it connects to the fuel door. How do I get past it or remove it without breaking it?
Weaktor is offline   Reply With Quote
Old 06-04-2012, 02:37 PM   #7
A4Audi4Fun
2008 Audi A4
Pull gently on the plastic piece - it should open the fuel door and at the same time provide enough additional cable length that it can be pulled out of the way, to allow access to the screw bolt.
Old 06-04-2012, 02:38 PM   #8
Weaktor
2007 Audi RS4
Thank you!
2007, 2008, a4, audi, b7, brake, bulb, cab, light, number, part, replace, tail
