| A4 (B6 Platform) Discussion Discussion forum for the B6 Audi A4 produced from 2002-2005 |
#1 | ||
#2 |
It begs the question did the shop slip a tooth on the belt. Too coincidental...
#3 |
#4 |
Yes, reduced mileage and power. Having done a timing belt, tensioner, and water pump 5 times (once on my B6, once on a B2 with an inline 5, and 3 times on my turbo V6 Nissan), there is no break in with these parts. I have heard of 3 cases where a botched timing belt job on a 3.0 V6 has cased knocking / pinging at elevated RPM and reduced power which were all fixed with a return to the shop. Never heard of this on the 1.8t, but it makes sense that in the first 10 seconds, the ECU will retard the normal advance based on the knock sensor during start via the VVT. If this is true, then it will never be able to advance the timing as programmed and thus your mileage and power will suffer. Finally, just simply too coincidental that this started right after the TB job was done.
That's my 2 cents. Last edited by lyleswk; 04-25-2012 at 06:29 PM. |
#5 | |
#6 |
2007 Volkswagen TouaregMy Garage Join Date: Jun 2008
You're not doing your engine any favors by idling; idling is a necessary evil of internal combustion engines: they need the momentum of a turning flywheel to keep going, even when the engine isn't doing any useful work. It also takes longer for coolant and oil to warm-up at idle than when driving, which contributes to sludge. Personally, as soon as the engine fires, within ten revolutions I'm in gear and putting the gas to work.
1996 Audi A4 2.8 1972 Datsun 510 |
#7 | |
#8 | |
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
#9 |
That's news to me; I've had turbo cars of one kind or another since turboing my first Datsun 510 back in the day. The thing is, soon as you have oil pressure, the turbo's bearings and seals are as lubricated as they will ever be. Now shutdown is different; if the turbine housing is really hot from a long pull up a hill or something, run it easy for a few minutes to bring the temp down.
#10 | |
Even on cool down, with turbos that are coolant and oil cooled... letting the turbo to cool down to prevent coking isn't as critical. This was true with older journal bearing turbos that were oil cooled only, but not so much with newer oil/water cooled turbos. |
| Tags |
| 01, 18t, a4, audi, b6, belt, coolant, idle, misfire, misfiring, rough, sensor, tempraerature, timing, warmup |
