#1 | ||
#2 |
Tech Guru
![]() Join Date: Oct 2002
You're probably OK. Did you have to rotate them clockwise? If so, I think you are OK.
4Driver4 "Never give up the throttle until the bitter end." -RC 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 2003 Mini Cooper S (Fun!) 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata SSB: track beotch 2003 GMC Yukon Denali XL: the anti-earth 2004 Dodge Dakota: hey, at least it's stick and 4x4 |
#3 | |
#4 |
Well I have been working flat out on this every minute I have.I am doing this in a storage unit a few miles from my apartment so I don't get many hours in the day when I can work on it
![]() But I just cranked her over for the first time, and she fired up as always, no hesitation. There was a blood curdling ratting noise on startup but it only lasted for a few seconds. Would that be pressure coming back to the chain tensioners? Anyway once that died away everything seemed 100% normal. I let it idle for a few minutes, gave it a little gas, and everything sounded OK. I am pretty sure I'd hear it if it was misfiring...right? I think this means I'm OK with the valves, but I haven't actually been able to drive it yet. I still have to reattach the bumper and a few other bits, and flush and bleed the coolant system. |
#5 |
That rattling sound was most likely the chain tensioner as you suspected. Since the engine is running w/o any contonuing abnormal sound, you're fine.
#6 |
2000 Audi A4Join Date: Aug 2011
I think you are good to go. Mine made that same rattle on starting but it only lasted long enough for me to say "s**t" to myself and then it smoothed out. No problems. Flushing the cooling system was the hardest part of the job. Getting the upper heater hose to expose the bleed hole was just so much fun.
#7 |
Senior Member
the hydraulic lifters pumping back up, before which there is a lot of valve train noise from the initial clearance. Regardless, it has always been brief and w/ no recurrence.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#8 |
2012 Audi Q5My Garage Join Date: Mar 2005
Hydraulic lifters on these engines will pump down over long periods of time and usually take a few minutes of running before it slowly fades away. The quick rattle sound for a few seconds is the cam chain tensioner.
#9 |
OK finally just drove it for the first time since I did the work. It drives flawlessly. The timing was perfect before so no improvement in power but that's ok, for a car with 190K miles it pulls like a train
It's safe to say I'm pretty relieved. Thanks to all you guys for helping me, and for helping everyone else too since I got as much help from the archives as anywhere else. I did notice something, maybe nothing, but there was a little vapour or smoke when I let it idle up to temp the other day, coming from around the rear of the passenger side valve cover. It was accompanied by a smell, which I can only describe as kind of like epoxy or glue. That smell was still there when it drove it just now. I am hoping this is excess gasket sealant and/or crud that has been shaken loose from the work I did and is now burning away? There are no signs of anything abnormal in the engine, gets up to temp very promptly and stays at halfway just like it always did. Oil temp only got up to about 175 on my short trip. |
#10 | |
