| Audi allroad Discussion forum for the original Audi allroad |
#1 | ||
#2 |
Here is the area.
#3 |
2002 Audi AllroadJoin Date: Oct 2010
That's your SAI pump.
Just remove the SAI pump and you should be fine. |
#4 |
That is NOT the SAI pump, though there are vacuum lines that connect it to the pump. This is an EGR valve (one of 2, the other being in the exact same location on the opposite cylinder bank). The pump is on the drivers side further back. I have removed my p-side valve cover without doing anything with that valve...once. The second time I have to remove my valve cover I couldn't figure it out again so I loosened the 3 allen bolts holding it on. They are a pain in the *** to get at...two of them at least, but you just need to back them out a bit so you gain a smidge of room. It will still be a bear, but you can do it. Good luck.
#5 |
Actually, the offending nipple is part of the "combi-valve" on the passenger side. This is the vacuum operated valve which opens during an initial start-up (for a minute or two) which allows fresh air from the secondary air injection (SAI) pump to enter INTO the exhaust gases. The nipple connects to a silicone hose which connects to an electrically operated solenoid. The solenoid is only operational during the warm up phase of the engine (at the same time as the SAI pump runs).
The combi-valve is held in place with two allen key hex screws which are a major pain to remove. These two screws are holding the combi-valve to an adapter mentioned in the previous post. The adapter is held to the engine block by the three screws mentioned. The two allen key hex head screw I mention are accessible under the flange just barely visible in your photo. None of these screws are easy to reach, but by just loosening one group of them it is possible to tilt the combi-valve and slip the passenger engine valve cover out. There is a gasket between the combi-valve flange and the surface to which it mounts...don't damage the gasket as you tilt the comb-valve. One of the two hex bolts is so close to the exhaust down pipe that you might need to cut the hex key a bit just to slip it into the bolt head. Maybe not, since all you need to do is loose the combi-valve, not remove it.
2002 allroad 2.7T Tip Black 2010 Jetta SE 2.5L Tip Salsa Last edited by Mr. Timewise; 04-24-2012 at 01:05 PM. |
#6 |
All you need is a medium size mirror like 4"x6" , light, and a ratchet setup to insert a 5 mm Allen, the rest isn't too hard once you see where to place the Allen
#7 | |
Remember, you don't have to take these bolts out, just back them off enough to get 3/16 - 1/4" play out of the valve. Link to replacement EGR/Kombi-valve: http://www.ecstuning.com/Audi-All_Ro...7T/Search/Egr/ |
#8 | |
2012 Audi Q5My Garage Join Date: Mar 2005
#9 | |
#10 |
Since I was stupid and screwed up calling it the wrong name, the Combi Valve actually isn't even in the Bentley Manual when you are trying to remove the valve cover.
Not a great design, but we have solutions! This should help you out, mate. Combi Valve Questions in Regard to Valve Cover Removal And this little tid bit might clear things up: Removal one bolt, loosen the other, and swivel it out of the way Last edited by 09mehashaw; 04-25-2012 at 09:53 PM. |
| Tags |
| 27t, allroad, audi, combi, egr, valve |
