NEW FEATURE at AudiWorld!!! We now have a fully integrated Wiki!!
Check it out!
For full post editing rights, please reply to this thread. Thanks!
For tips on using the forums please visit the following page: Forum Tips Be sure to check out Threaded View!!!
facebook users, please become a fan of AudiWorld's page
We've gotten complaints about spam/virus Private Messages. Any such messages are completely bogus, and should be ignored completely. Read more here.
Auto Detailing DiscussionDiscussion forum for the in's and out's of properly detailing your ride
Can this or will this end the clay bar? - NanoSkin AutoScrub
NANOSKIN Autoscrub 6 inch Pad - Better and Faster than Claying
Wow is all I can say about this new tool and new technology. I believe this will change the way most pro detailers and DIYers will prep their cars. This is truly a time saver and will pay for itself after a couple detail jobs. We have spent in some cases 1-2 hours claying and prepping a midsize sedan (in rough shape) we recently tested the AutoScrub on an Audi S8 and we were finished in about 15 minutes! You really won't believe this until you try it yourself. The AutoScrub will make you leave your clay bar behind.
NANOSKIN AutoScrub works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars.
A dual action orbital polisher is required. AutoScrub will safely and easily removes paint over spray, water spots, tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic.
AutoScrub works great with your favorite detail spray or clay lubricant. Unlike the clay bar, the AutoScrub can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AutoScrub on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it.
AutoScrub allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required.
Features
- Lasts up to 4 times longer than clay bars
- Glides on & off easily for a slick finish
- If inadvertently dropped on shop floor, simply rinse clean
- Up to 50-60 uses before you need to replace it
Directions
1. Thoroughly wash vehicle free of dust, sand, and dirt.
2. Mist sufficient detail spray or clay lubricant onto the surface evenly.
3. Polish the surface with dual action orbital polisher using light pressure (Low Speed).
4. Wipe off residue and move on to compound and polishing or even go straight to your last step.
Important tips:
- Sufficient lubrication is crucial to the AUTOSCRUB application.
- DO NOT use water
- DO NOT use with rotary polisher.
Take a look at the 3 offers we have. Pre Order Pricing is in effect, we should have the first wave by Friday.
