#11 | ||
Audi 200 5 speed Quattro Turbo 2.2 year 1991 Stock. Audi Coupe GT 1985 2.3 |
#12 |
Yeah, when I have some time later I will look that up for you. Glad you figured out what was going on. Now to fix it...
![]() -Rog |
#13 |
Hi guy,s
Fixed the problem. But you won,t believe what the problem was... The starter solenoid, there is a extra power tab on the solenoid which supplies power to the Cold start valve when you first start the engine, this solenoid had so much crud around it that it was causing a poor connection, after removing the starter motor and cleaning both starter and solenoid replacing the connectors power was restored to the CSV, starts and runs great now. So if you have a cold start problem, check the Two spade connections on the starter solenoid, the one furthest from the engine should have power when you crank the engine, if you don,t there's your cold start problem....... Thank you for your help Roger and friends.
#14 |
1987 Audi 4000My Garage |
great work, these cars are just wild when it comes to troubleshooting. No proper manual could explain some of the things that happen to these cars.
Beleive it or not, i have had the exact same problem. What i did was put in an old 1981 Audi 5000 starter into my 87 4000. it fit, and it cranked perfectly. BUT, the solenoid only had positive and negative leads. the small black wire actually triggered the csv or the fuel pump (one of the two)and it didnt have a place to fit. I couldnt find out why my the car wouldnt start until i changed the solenoid from my old starter. good luck with the car, treat it well and it will last a long time
Audi Vorsprung Durch Tecknic |
| Tags |
| 1987, 1999, 200, 27t, 4000, 4000cs, a3, audi, cold, idle, minute, quattro, smokes, start, switch, wont |
