| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
2001 Audi A8Join Date: Apr 2012
#2 | |
So, if the gauge climbs above the "normal" mark, the temp is actually well above normal range...2 marks up is seriously high. Running high rpms will cool down a motor with a failed thermostat...Mine is on it's 3rd, installed at 100K miles...very prone to failure in these cars for some reason. High rpms seems to force coolant through the bleeder hole in a thermostat stuck closed. Running max heat and max fan will also cool down the coolant. I'm guessing a failed thermostat over a coolant temp sensor...judging by your mention of cooling things down with high rpms...a failed coolant temp sensor would not respond to that, but a stuck closed thermostat always will. You can read the true temp of your coolant with a climate control trick in the link below...it's code #102...easy to do and a useful tool built in that most D2 owners don't ever know is there. Check it out >>> http://forums.audiworld.com/showthre...t=secret+codes
Mine: '01 A8 SWB Hers: '03 Allroad 2.7T Dog's: '90 Passat wagon |
#3 |
Silver
Thnaks for info....Any estimate on what I am looking at ($$) for stat replacement? Also, shouldn't that Aux fan kick on periodically? It only runs when econ switch is off Thnaks......GH |
#4 | |
2000 Audi A8Join Date: Nov 2010
From what i've noticed, my aux fan turns on everytime i turn on the a/c or heat. as far as the price goes, I don't think its cheap. The thermostat is in the front of the engine(I think behind the timing belt), which means you will have to have the timing belt removed using special tools and what not to get it off/on. |
#5 |
Also, the thermostat itself should only be 20$-30$(with the O-ring)
#6 |
My local dealer quotes people about $500 for the thermostat change...it's buried deep. Some "skilled" home mechanics have slightly shortened the procedure, but not by much...still very involved, requiring a good deal of knowledge.
The aux fan always runs with climate control in "auto" regardless of temp. The fan kicking on by itself (due to heat) is controlled by a switch at bottom right of radiator...coolant IN radiator must be well over normal range temp to kick it on.
#7 |
Thaks all - good info
OK - seems a stat issue - to be replaced As for the elec aux fan - seems it should kick on, based on temp sensor, only in Auto mode? I don't ever see it engaging when climate control is in "econ on" mode - is that a faulty sensor or normal? Im in econ mode all year except summer |
#8 | |
It's possible for the motor to overheat, with radiator water remaining cooler...a closed thermostat is preventing low temp coolant from getting into the block and unloading overheated coolant into the radiator. The coolant temp sensor is on the back of the motor...and the thermal switch for the fan is mounted on (and reading coolant in) the radiator.
#9 |
Silver
Earlier in the thread you said temp needle showing 2 ticks up is very high. When I say 2 ticks, I mean needle is at 12 O'clock....Doesn't go past that. Keeping in mind your comments about the needle is not a good indicator, just curious if that needle reading is very hot. I will also try the codes you suggested - good stuff Thnx |
#10 | |
The "secret codes" are REALLY easy to use...I do constantly. With climate control on, simply press the recirc and upper vent button drivers side at the same time (2 fingers at same time)..then use the drivers side temp button(s) to scroll to "102". The passengers side temp window will show the true temp (Celsius) constantly, so long as the temp sensor is working properly. You'll notice that the temp gauge will hold dead steady at normal mark (90C) while temp is actually 81-100C, and will not increase until true temp goes over 100C. Normal temp should be 87-93 in most cases...esp with car in motion at any outside temp.
| Tags |
| coolant, effect, gauge, indicator, passat |
