Go Back   AudiWorld Forums » Technical Discussion » Motors » 2.7T V6 Discussion
Old 04-16-2012, 04:30 AM   #1
vtraudt
Send a message via Skype™ to vtraudt
Default PCV system - spiderhose
IIRC, there are 2 versions of the spider hose on 2.7T.
Is there a simple 'tell tale' to determine which version I have on my 2002 Allroad 2.7T? I have a spare engine that is soon going in (from an S4) and I need to replace the corrugated plastic hoses.
Also: can (and should?) the PCV valve itself (I assume its the plastic part shown at the top right in the pic below) be replaced?
Part number? Source?
Since I am installing larger turbos (higher boost), I also would like to incorporate a catch can.
Can someone put 'arrows' in the photo to show the directions of flow, and where the catch can should be spliced in?
Photo below is NOT from either of my engines, just for reference:
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune
1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune
2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC
2001 Audi Allroad 2.7T quattro manual; custom stg 1
1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage.
www.regulatorfix.com
www.kraftwerkturbo.com
vtraudt is offline   Reply With Quote
Old 04-16-2012, 01:03 PM   #2
Bergelvis
2001 Audi Allroad
Default PCV
That valve in upper right goes to the y-pipe, and is called the pressure limiting valve. Search for SSP 198. Its easy to find an english version in pdf format. Page 30 of that ssp has a great picture of the PCV system. The ssp describes the purpose of that limiting valve. A new breather hose assembly comes with that valve, but not a new PCV. The PCV valve is called the non-return valve in the ssp. The PCV or non-return valve would be attached to the hose that attaches to the intake manifold. I think it is the rubber fitting at the end of the second hose in your picture. To test it you should be able to suck from that fitting, not blow (mmm, mmm, good). I've never seen a bad one.
Make sure you clean or replace the valley pan gasket inside the crankcase ventilator (pn: 078103547F), which is under the intake manifold. I've seen crankcase ventilators 100% clogged, make sure you clean it! If you clean out that stuff, I'd probably blow off the catch can. I believe a catch can would go between the distributor piece and the PCV. Therefore; it probably wouldn't keep the crankcase ventilator and gasket from clogging. I don't think bigger turbos would change how the PCV system works.
To find your breather hose assembly, Try going to ECS tuning, and where it says search by part # or keyword, type in "2.7t breather hose". Call them if you're not sure which one it is. Unless they are broken, I usually just clean them out with paint thinner, and use compressed air to blow them dry, being carefull not to blow the wrong way on either the pcv or the plv.
Bergelvis is offline   Reply With Quote
01, 03, 18, 18t, 2002, a4, allroad, audi, blow, clean, pcv, pcvsystem, pvc, quattro, system
HTML code is Off
