#11 | ||
2000 Audi A4Join Date: Aug 2011
#12 |
spell check dammit Bob! (resistance and again)
#13 |
Tech Guru
![]() Join Date: Oct 2002
Having done this a few times, I can say the only time I ever used anything of than the pin was when the hole was so badly sludged that it needed to be cleaned out first. The hole is tapered. Close enough it good; the pin will move the crank as it goes in. Since you got the cams lined up first, there was nothing to worry about.
4Driver4 Growing old is mandatory; growing up is optional. 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 1980 VW Scirocco (mid-life crisis car) 1983 Mazda RX-7 (revolutionary sports car) 2003 Mini Cooper S (just because) 1995 Mazda Miata, Superdupercharged(anti-Audi) 1999 Mazda Miata SSB (track beotch, no plate) 2003 GMC Yukon Denali XL (the anti-earth) 2004 Dodge Dakota (hey, at least it's stick and 4x4) |
#14 |
Thanks for all the help gentlemen. I'm learning.
#15 | |
#16 |
I am sorry for giving somewhat bad information about it being related to the belt - thanks for further explaining Sloop.
I would not say you are lucky - like 4D4 said, it's kind of unlikely that it's off so far that the pin won't go in (at least IMO), and if the pin goes in, it will line up the shaft. If you just line up the shaft with the marks, however, it could still be off (which the pin would correct) - and it could be off more if there is something wrong (like Sloop pointed out). It's best to just use the pin and be sure... |
#17 |
How in the world were you able to screw it in by hand??? I've looked everywhere and the only access I found is to rig a couple of extensions in order to reach the hole from the left hand side.
http://pictureposter.audiworld.com/105216/002.jpg |
#18 |
once I found the plug and got it out I just reached the locking pin up in there and carefully started to thread it in. It went in all the way by hand and I checked the crank to make sure it was locked. I think I got lucky according to what I read on the forums.
Anyway I get to do it all over again this weekend. My brand new timing belt tensioner broke last week. Hope I didn't crach a valve or 12. |
| Tags |
| 2001, 2004, a6, a8, audi, c5, crank, crankshaft, instalation, install, lock, locking, motor, pin, s6, tool |
