#1 | ||
#2 |
iggy switch.
Remove main cluster... swap in new switch. also have a look at the trunk lid wire loom ![]() My bet is the Iggy switch.
"Spartans never die" Spartan 051 - Kurt Status:MIA |
#3 |
To test if that could be the problem or something along those lines, turn the car key to the on position and then short the solenoid + and the main battery + on the starter with a big screwdriver, see if it starts then (dont touch anything else). More or less that is doing exactly what the ignition switch is doing when you turn it to the start position. Just make sure that it is in neutral/park so you dont get ran over haha. This isnt the best thing to do , but it will help you eliminate some of the things the problem could be.
#4 |
I would agree with Luxus on this ign. switch. But one thing everyone should know is how to pull the codes on your car... if you don't know already. This website should help you out a bit. http://www.12v.org/maintenance/dtc.php
Cheers
1994 Audi 90 CSQ (Tornado Red) -SXTB+ -HVRS -DIY Maf -Vap Acetron CA Bushings -Vap Snub -Allroad Tranny Mounts-Gasket Matched Heads -Aux Gauges -Apikol Diff Bushings- BBSE/Urs4 Bilstein Sports- VAP Promounts You Can't catch a Quattro in the snow!
| Tags |
| 1994, 1995, 90, 90s, audi, crank, firebird, mid, quattro, s4, security, turn, wont |
