#11 | ||
#12 |
Verify that you don't have a clogged radiator. The sensor at the bottom of the radiator will not see an overheat condition if it is clogged. While driving on the highway does the temperature remain normal, but start to climb when the car isn't moving? This will also indicate that the radiator is clogged.
#13 |
At the fuse box under the hood, next to the firewall, there is no 40 amp fuse. Just a few 30amp fuses. Last edited by sugaryling; 04-19-2012 at 12:19 PM. |
#14 | |
#15 |
Yes, I am working on a C4. I was just referring to how the C4 has no fan controller like in my C5.
Do you know where I can find the S42 inline fuse? I followed the fan wires but it just disappears into the chassis at the firewall. I assume it goes into the fuse box at the firewall. |
#16 |
The fuse is located behind the storage compartment on the driver side underneath the steering wheel. Yes you will have to remove the storage compartment shelf.
#17 |
![]() 1 open 2 Second Speed Coolant Fan Control (FC) Relay 3 Coolant Fan Control (FC) Relay 4 open 5 open 6 open 7 open 8 open 14 Power Seat Circuit Breaker 1, Driver's Seat 15 Fuse for luggage Compartment Socket 16 Power Window Circuit Breaker Front 17 Power Window Circuit Breaker Rear 18 Fuse 1 for control module - ABS 19 Coolant Fan Fuse 20 Coolant Fan Fuse 21 Control module fuse for coolant fan 22 open 23 open 24 Power Seat Circuit Breaker 2, Passenger's Seat |
#18 |
It is located on the driver side between the front tire and the bumper. The only way to get to it is from underneath the car. The positive side wires for the fans are connected to the controller and the negative side wire is connected to a ground that is located at the topside of the engine bay.
#19 | |
#20 |
I don't know why I said that my fans don't come on when I turn on the AC but they do now! I must've looked at it briefly or forgot to hit the AC button and just turn the temp down. Regardless, both fans com on when I turn on the AC.
| Tags |
| 1999, 42, a4, a6, a8, audi, avant, box, c5, diagram, engine, fans, fuse, panel, relay, wont |
