| Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Sponsored by: Tire Rack |
#1 | ||
#2 |
AudiWorld Expert
![]() My Garage Join Date: Mar 2000
some observations.
Almost all performance tires are noisy. Most All Seasons give you a quieter tire and longer life. You should also check what you did with your existing Contis: 1. Did you rotate them every 5K miles? 2. Did you have the alignment checked? 3. Did you use the correct tire pressures per the recommendations in the manual (not just the sticker on the car [US requirements now only show the max pressure to use for a fully loaded car on the stickers]. I personally use the min pressure the manual recommends =2lbs 4. Did you check those pressures every three months All those things I recommend help the tires to wear correctly and reduce the possibility of noise. Tire noise is easy to differienate from wheel bearings as the pitch of the noise will change vs the road surface type.,
#3 |
Audiworld Basic Sponsor
Irrelgular wear will cause even quiet riding tires like the Pro Contact to become loud over time. If you were to take a brand new set of Conti Pro Contact tires and a new set of Extreme Contact DWS tires, the Pro Contact would be smoother and quieter and would stay quieter longer than the DWS under the same conditions.
The three most quiet riding tires we sell in the 245/40R18 size would be the Bridgestone Turanza Serenity, the Conti Pro Contact, and the Kumho ECSTA LX Platinum. Tires http://www.tirerack.com/a.jsp?a=AR8&...ires/index.jsp
![]() Gary@Tirerack.com Tire and Wheel Forum Moderator The Tire Rack, Sales Rep Reference 'Gary/Audiworld' as 'previous contact' when you order at our site. The TireRack Tech Center 1-877-522-8473 ext 4386 |
#4 |
![]() Join Date: Mar 2003
.. and a 35 series tire will be very noisy. Want quiet - get an all season or better yet, a "touring" tire, and get it in a more reasonable size.
G
glenahan@vee-eff-email*dot*net |
| Tags |
| find, quiet, tires |
