Old 04-11-2012, 08:58 AM   #1
old96A4
Default Thermostat leak issue
has any one had the thermostat leak after change. I did my timing belt and replace the thermostat, gaskets etc.. now I think I have a leak , I just see alittle water after driving awhile but nothing major. but I've had to fill my water resivor a few times now after a few weeks. I can smell it but don't see much. Could it be the water is evaperating on the hot engine?? can't seem to find anything else. this is a tough one. this is all a guess too. I know these 3.0 engines have problems but nothing before I did the timing belt service. I'm afraid to add anything to the anti-freeze. any comments..
2007 Q7 3.6 Premium
2003 A6 3.0
1980 MGB Limited
1959 Austin Healey 100-6 (under restoration)
2005 Ford Escape - Daughters
old96A4 is offline   Reply With Quote
Old 04-11-2012, 02:31 PM   #2
RMsALFA
don't add any crap to the coolant !
2001 A6 2.7t 6-speed; ECU & BiPipe by APR
RMsALFA is offline   Reply With Quote
Old 04-11-2012, 02:41 PM   #3
SloopJohnB@mac.com
2002 Audi S6
SloopJohnB@mac.com's Avatar
Chances are you'll have to rip it apart again and redo the thermostat/gasket. Sucks to be you.
SloopJohnB@mac.com is offline   Reply With Quote
Old 04-11-2012, 05:08 PM   #4
rocketman4321
You may be able to see it--just below the t-stat housing on the front of the engine. There's s little recess where the coolant tends to dribble.
I managed to (be stupid and) crack the plastic t-stat housing while doing this. It was a very small crack leading away from one of the mounting bolts. I'm not sure if the 3.0's have the plastic housing or the metal one, but you might want to check if you think you may have stressed it.
If I recall, it was possible to get the housing off without completely removing everything, but it was still pretty invasive. But with practice comes speed!
rocketman4321 is offline   Reply With Quote
Old 04-11-2012, 05:28 PM   #5
Prospeeder
those crappy plastic thermostat housings crumble apart and crack all the time. To save doing it again i would get the stat housing as well. And do not use any sealer or RTV on the o-ring when installing.
1992 Audi 100 CS Quattro
1990 Audi 200 Avant Turbo Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
Prospeeder is offline   Reply With Quote
Old 04-26-2012, 12:56 PM   #6
old96A4
I have a steal housing, all I did was replace the left bolt with one that has a head on it and crank it down, so far so good, those allen head crap you can;t get anything down there to tighten them. the right side I can get a allen socket on it and tighted that down. haven't had to fill my resivor yet. but I'll give it some more time, we'll see, may have gotten lucky...
2007 Q7 3.6 Premium
2003 A6 3.0
1980 MGB Limited
Old 04-26-2012, 04:25 PM   #7
SloopJohnB@mac.com
2002 Audi S6
So you didn't have to tear it down and reseal the thermostat housing? Just replace one bolt?
Old 05-03-2012, 03:32 PM   #8
old96A4
Yes that's right. You can take the thermostat housing off with two bolts after you take the plastic covers off. This is the 3.0 engine. So far so good. The Allen head bolts are all rusted.
2007 Q7 3.6 Premium
2003 A6 3.0
1980 MGB Limited
Old 05-03-2012, 04:53 PM   #9
n3985
2002 Audi A6 Avant 3.0
I had same issue on my 3.0 and new thermostat. When I installed the new one I didn't push the thermostat flush with the surface (towards firewall) so the gasket was pinched. With new t-state #2 I pushed it towards firewall while a friend tightened down the two bolts, no more leaks
n3985 is offline   Reply With Quote
100, 1991, 28, a6, audi, fsi, leak, leaking, replacement, thermostat
