Old 04-08-2012, 11:11 AM   #1
austin.schipper
Default Strange things while bleeding clutch
So the clutch on my 91' 200 went out a while back. The master cylinder had been replaced recently so I assumed it was the slave. To make sure though I pumped the pedal a few times to make sure it was pushing fluid out of the line the feeds the slave. Yesterday I got a new slave cylinder installed and started working on bleeding it. I made a crappy little pressure bleeding setup which seemed to be working surprisingly well. It only holds pressure up to 5 psi so I wasn't worried about it damaging any seals.
So far I have spent about three hours and four pints of brake fluid bleeding. This seemed excessive but my pedal had pressure for about the last half of the throw by this point. Then I got a massive bubble coming out. At first I thought great this should be most of what is left in the system. But fluid just stopped coming out. When I went back and tried the pedal it sprung all the way down to the floor, no pressure at all. I tried for about another hour to get fluid through the system but neither my pressure bleeder or pumping the pedal is doing anything. It sounds like the master is empty when I move the pedal up and down.
The reservoir never went dry. I'm at a loss as to where all the air came from. Could the seals on my master have gone out? And if this is the case why isn't the pressure bleeder pushing fluid through anymore?
austin.schipper is offline   Reply With Quote
Old 04-08-2012, 10:44 PM   #2
yodasfro
yodasfro's Avatar
There is the possibility that when you installed the slave the end of the piston push rod didn't get seated in the dish on the throw out bearing lever. It does require quite a bit of force to get the slave installed correctly. This tends to happen more with aftermarket slave cylinders such as FTE brand because the push rod isn't held tight in the piston like on the sachs slave. So it tends to flop around making it harder to get things lined up. If it was easy or almost too easy to get the slave seated it's worth pulling it out to try again. You'll need to undo the hose though otherwise it will be near impossible to get it seated again.
Austin 92 urs4 91 200 20v 90 90q 20v 88 5ktq avant
yodasfro is offline   Reply With Quote
Old 04-09-2012, 02:45 AM   #3
RussB
I spent hours bleeding my clutch and eventually replaced both the slave and master cylinders, and still it wouldn't thoroughly bleed. Eventually I replaced the hose, and all bleed problems disappeared. YMMV.
Russ Bellew
1988 5000CS Turbo Quattro
My blog
http://russbellew.com
RussB is offline   Reply With Quote
Old 04-09-2012, 04:48 AM   #4
Kneale Brownson
IF you can get someone to pump the clutch while you watch the hose, you may see it bulging or seeping.
Kneale Brownson is offline   Reply With Quote
Old 04-09-2012, 06:47 PM   #5
austin.schipper
Cool thanks guys. WIth the amount of air I was getting out of the bleed valve I was starting to wonder about the lines being an issue. But this weekend when I have time Ill pull the slave out again. There definitely was some slop in the piston and I can see how it might have missed the dimple in the throw out bearing lever.
Old 06-12-2012, 10:15 PM   #6
pureroundcircle
Bleed it backwords. Use a pressure oiler bottle like the $3 one harbor freight sells, open the bleeder on the slave and pump it in backwords through the bleeder screw. It works VERY well for the 5000's and the last 200 I've had.
Here is the bottle I'm talking about: http://www.harborfreight.com/8-oz-hi...ler-66350.html
they have an even cheaper version in the store.
pureroundcircle is offline   Reply With Quote
Old 06-14-2012, 04:54 AM   #7
88A5TQ
1988 Audi 5000
88A5TQ's Avatar
Send a message via ICQ to 88A5TQ
When I bled my 5000's clutch I had the same issues. I used a cheap brake bleeder and a nice amount of teflon tape on the bleed screw. Just do it the traditional way with a helper to work the pedal and you bleeding the system while closing screw before they pull the pedal back up. Bleed screw threads, even new, can suck air into the sytem. Good luck.
88A5TQ is offline   Reply With Quote
