Go Back   AudiWorld Forums » Technical Discussion » Motors » 1.8T Discussion
Old 04-06-2012, 07:40 PM   #1
grimreaper_12b
Default 01 TT won't start after driving
Situation: I drive car to a Location, IE store. I come out half an hour later it will not start. After calling it a few names several cranks, I give up and come back an hour or so later. I turn the key and it starts right up.
Repairs: coils, plugs, fuel pump relay no check engine light and I pulled the fuel line, sprayed my other car.
What suggestions do you all have for me to look at next?
thanks.
grimreaper_12b is offline   Reply With Quote
Old 04-07-2012, 06:13 AM   #2
Peter Badore
thanks.
You should scan for fault codes. VAG-COM is best. You may have a failed when warm crankshaft position sensor with fault code P0322.
Peter Badore is offline   Reply With Quote
Old 04-14-2012, 11:36 AM   #3
grimreaper_12b
Do you suggest the USB to Computer or one of the hand held units? I do not want to be stuck at some auto parts store to have them scan for the code.
I also might change out the sensor any ways to see it that's the quick fix
Old 04-17-2012, 05:24 PM   #4
Peter Badore
You should but the genuine system from Ross Tech then install in a good computer. I use a Mac Book. Lots of money but worth it if you own Audis or VWs. There are a lot of VAG cars in my family including some high miles cars that need lots of attention.
Old 04-22-2012, 11:39 AM   #5
grimreaper_12b
Thanks, I will look into it. I have a 01 TT and a 03 Jetta VR6. now I am looking for something for my 15 year old, that cheap.
Old 05-05-2012, 06:09 PM   #6
Its Eugenius
I had the same issue with another car, not an Audi, but the mechanic I asked advice said it could be the ECU or throttle body controller tweaking out. I replaced the ECU on it and been driving it for months being able to start it from first attempt. Before I would sit in parking lots trying to start it over and over again. Not sure how it is on VWs, but the security system sometimes would not fully disable, so I had to lock the car, then unlock it and it would start right up.
Its Eugenius is offline   Reply With Quote
Old 06-30-2012, 05:39 AM   #7
grimreaper_12b
I finally purchased a code reader. fault code P0322 came up when I went to start it. I was hoping for the Cam sensor, easier to reach. Now the TT is running great. Thanks for all the advise
car, driving, start, strat, tt
