#11 | ||
#12 |
This has now turned into a full blown nightmare. I'm still missing some of the broken pieces of the failed cam chain tensioner pad. I'm afraid that they may be lodged under the cam chain or, worst yet, between some of the valves and pistons.
The car started initially after replacing the broken top pad, but it rattled loudly so I turned it off and reopened the valve cover to pick off another small piece of the old failed pad. I restarted the car after replacing the valve cover back on and the engine ran like crap! It wouldn't idle right like only half the cylinders were firing. Sure enough I get the following codes: 16684 Random/Multiple Cylinder Misfire Detected 16687 Cylinder 3: Misfire Detected 16688 Cylinder 4: Misfire Detected 16689 Cylinder 5: Misfire Detected 16690 Cylinder 6: Misfire Detected Is it possible that I may have affected the timing when I replaced the broken can chain tensioner pad? I did have to "tap" it into place with a hammer since the cam chain tensioner tool was only able to loosen the chain so much. My daughter's 2004 Mustang threw multiple misfire codes last summer and it ended up being a bad ignition coil after I had replaced the plugs, ignition wires, and MAF filter. I still have the original ignition wires and ignition coil on my 2000 Audi A6. Could this be my problem, too? The car was idling and running smoothly before I worked on the stupid cam chain tensioner though! Dang it! Now the engine won't even start anymore! I'm afraid that I'm gonna have to eventually dismantle my engine in order to fix this problem correctly. I had the timing belt, thermostat, and water pump replaced at 100K miles and my odometer now reads 133K. Although I will have to disassemble them in order to work on my cam chain tensioner on the driver's side, I sure hope that I won't need to replace those at this time. Any tips on how to deal with this problem? Any help would be greatly appreciated.
http://pictureposter.audiworld.com/105216/002.jpg |
#13 |
Tech Guru
![]() Join Date: Oct 2002
If you didn't remove the cams to do this job, you need to.
How did you check/replace the bottom guide? Did you check chain timing before assembly?
4Driver4 "Never give up the throttle until the bitter end." -RC 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 2003 Mini Cooper S (Fun!) 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata SSB: track beotch 2003 GMC Yukon Denali XL: the anti-earth 2004 Dodge Dakota: hey, at least it's stick and 4x4 |
#14 |
I really think you should pull the cams and take a look on this one. It's the old saying, "If you don't have the time to do it right, when will you have the time to do it over?"
However, the mist fire problem may or may not be a cause of the pads directly. You have misfires on one head mostly. I bet the cylinder 3 misfire is really just because of the random misfires on the other head throwing off the timing. Did you connect the cam adjuster electrical connectors correctly? How about the hall sensor connectors? Is it a ticking or an exhaust puffing sound? Is your combi valve on correctly and tight? At this point, I would pull the timing belt, double check the timing, pull the cams and replace the pads on the adjusters fully. It's probably about 10+ hours worth of work, but replacing a head is probably 20+ hours of work easy. Replacing a piston that is damaged by a collision will put you in a position that you may as well drop a new engine in the car. While you're in there, you may as well replace the cam seals and plug also.....Timing belt components should still be good for another 40,000 - so you could do those later.... |
#15 |
How can you tell that this was existing??? is there a sound/noise? |
#16 |
Loud rattling noise and sudden rough idle. Fortunately, it didn't happen at higher speeds. I did rev the engine up a few times to see if the rattling would go away. I hope that I haven't done much damage by doing so. I'm such a freakin' caveman most times... :-(
#17 | |
Let me tell you what, that Solara drives like new even with those many miles and having been used by my nephew all the way through his last year of his Phd Degree at Emory. I can't help but think that a Toyota or Lexus would have been the way to go the year I bought my 2000 Audi A6. Regardless, I'm not about to give up on my baby at this point. After all, she has been with me through thick and thin all these years. Owning an Audi has forced me to learn how to work on cars more than I wanted to but, in the end, I've become a more mechanically inclined man because of it. I've learned a lot from my Audi and, unfortunately, the lessons continue. Thanks for everyone's input. You guys are the best! :-)
#18 |
I have 188,000 on my Audi and it still drives as good as new.
Of course, you're right - I had to learn how to fix some things along the way. I bought this car with 93,000 on it 2 years ago and have replaced both front axlex, the timing belt and all components, valve cover gaskets, cam seals, cam tensioner gaskets, wheels, brakes, a brake switch, some bulbs, engine oil and filter, and 2 transmission fluid changes. Other than that, I just drive the hell out of it....but I still wish shortcuts worked. It sure would be nice!! Good luck with pulling the cams...let us know how it goes. |
#19 | |
#20 | |
UPDATE: I think I found the culprit after hand cranking the crankshaft to TDC. Is this the intake cam sprocket? These are the driver side camshafts. Anyway, I must have made it jump off by a tooth when I was "tapping" the top cam chain tensioner pad into place between the chain and the cam chain tensioner. ![]() ![]() I found instructions on how to replace the cam chain tensioner without dismantling all the belts in Audiforums.com: http://www.audiforums.com/forum/diy-...er-diy-101340/ What do you all think about his instructions? The problem that I see is that this cam sprocket is on the driver's side and the timing belt rear cover is partially blocking the cam chain tensioner itself. There's hardly any wiggle room for the cam chain tensioner to be lifted high enough and pulled out. Going through the motions of the timing belt replacement steps may be my only sensible recourse at this time. Yes? Besides, I'm still lacking a piece of the old cam chain tensioner pad that's roughly a square inch in size. I've got a hunch that it may be under the cam chain somewhere.
| Tags |
| 90, 99, a6, audi, belt, cam, chain, changed, front, gasket, misfires, pad, tensioner, timing, vr6 |
