| Audi allroad Discussion forum for the original Audi allroad |
#1 | ||
-05 Audi AllRoad 2.7T (Current) -05 Audi A6 3.2 (Current) -01 Infiniti i35 (Sold) -94 Acura Legend LS (Sold) -93 Acura Vigor GS (Sold) -89 Civic Si (Sold) |
#2 |
Air suspensions is DIY type repair yes, if you are skilled enough to do a brake job, you can / should be able to repair air suspension yourself. Torque converter failures are more common on earlier models. Remapping the ecu is fine, it won't blow up your car.
I would want to know how long ago, or what if any repairs have been done on air suspension. That should give u some idea of how long it may be until more repairs are needed. IMHO, air bags usually last bout 3 years (front), the rears rarely fail. If timing belt hasnt been done already, perhaps can get allroad for say $10k, the money saved should pay for that repair.
03' allroad Atlas Grey; Body Clad painted 03' Nissan Maxima Grey, Smoked tail lights, Neuspeed Chip, K&N Filter, H-Sports (hard), Mufflers removed (straight pipe), Mandrus Regenmeister Rims: 19x8.5 w/25mm offset on Pirelli 245/45-19" Tires, 20% window tint. 10' Cadillac CTS-V (grey, 6 speed manual, all factory options, no mods yet). |
#3 |
![]() Join Date: Apr 2003
Make sure the tranny works well in all gears--reverse too--with no slippage and at full operating temperature.
Most of the air suspension parts should be considered "wear items" and you can replace them as DIY items if you have some mechanical ability and the correct tools. There are lots of DIY reports available. |
#4 |
I looked at the AR this past weekend and it started and sounded pretty good. Seller has all records of maintenance including full air suspension replacement done by Audi which is a huge plus. Now the bad. I spotted somewhat fresh minor oil leak residue in the upper rear part of the engine, should I worry about this or is this minor? While driving it felt very well in all gears however when I pushed it hard I could not hear the turbos, are the turbos quite when stock? I ask because I have only driven 1 AR before and it was chipped so the turbos could be heard when pushing it hard. Last but not least, I opened up the spare tire compartment only to find sitting water in there. Water looked like it had been there a while and seller was “surprised” to see this supposedly. Is water leak common in these cars? Should I worry about the water intrusion in the spare tire compartment? Thank you in advance and hope to hear from you soon.
#5 |
Oil leak is perhaps clave cover gasket or cam chain seals. Either are fairly cheap fixes (if either or both problems exist, their fairly easy to repair) and I'd expect any vehicle that's older than 5-6 years to at least need valve cover gaskets. My allroad is chipped, I sometimes push it hard, but I never seem to hear the turbos. . Nothing like the way past turbocharged cars I've owned have sounded. In those cars, it was easy to tell the car had turbos. The allroad has always seems more quiet to me (oh, but I have my exhaust moded, so probably why I can't hear them turbos). For the water leak ; remove spare tire cover, drain/clean/dry out existing water. then have a friend join u at the local car wash. one person folds the rear seat down and hops in the back, the other sprays the car. Whomever is inside may be able to locate the leak. That's a decent idea.
#6 | |
#7 |
2005 Audi AllroadJoin Date: Aug 2004
If the turbos are imperceptible to hear, they're fine.
#8 |
When the turbo's start to sound like a dentist's drill, it's time to look into replacement options.
-Mike |
#9 |
Got it... Thank you so much for the info. Has anyone added the RNS-E to a non Nav AR? If so what's involved in just the head unit or other stuff? I am also interested in a Vast re-map but along with that any intercooler options? Straight pipes, is there any hp gains or just cool sound?
#10 |
search the forums, check out the tech articles in the resources section (top nav), and Google "Stoney's A6 links"
2005 AR 2.7 Black: GIAC tune, 710N, H-sport sway bars, Depo LED taillights, akebono pads delete Past Audis: 2001 A6 4.2 | 2001 A4 1.8T Quattro | 1993 100 CS Quattro | 1984 5000 CD turbo FWD |
| Tags |
| 05, 32, a6, allroad, audi, cover, pipe, removing, spare, straight, tire |
